2008 6.4 no cruise control with new 9r05 update
sohfast94
RE: u174 issue
Post by sohfast94 »
Make sure your dsdl is on auto connect make sure that you click Send CROM file to tool....
Insert Clever comment here...
duncan
RE: u174 issue
Post by duncan »
Got the same issue-- file will not decompress-- dies at line 124. Predator autoconnects properly, using "send CROM file" -- had exactly the same issue yesterday with 9t05c and 9t05d files. Something is different at that point in the files between the test and released versions...
Pesky User, running 2008 6.4l PSD F450 CC LB, 5000 lb truck camper in bed, desperately searching for better fuel economy...
duncan
RE: u174 issue
Post by duncan »
Another clue, perhaps-- tried to download the 9r04 file and that also failed to decompress. 9r05 does load into the tool, but that's where I came into the discussion-- no cruise after tuning :-)
duncan
sohfast94
Post by sohfast94 »
Here use this...
File removed...
duncan
Post by duncan »
If that's the same file you posted yesterday afternoon at 4:44 or so, it didn't decompress for me this morning ("failure at line 124," previous post), with a similar result for the other fellow who tried it at 9:34 last night. The latest crom that has worked on my truck (with cruise control OK :-) is 9r02.
sohfast94
Post by sohfast94 »
No I don't think so.. You should try and load this one... Make sure all your windows etc.. are closed when you do try and load it.
duncan
Post by duncan »
OK-- off to the truck to warm it up and restore to factory tune. the issue I had with the earlier file was loading it into the Predator. Will advise once I get back inside and thawed out-- 33 degrees and 20 mph wind. Would that I were doing this in Delray Beach :-)
duncan
Post by duncan »
As before-- 9t06a crom file will not decompress and load into the U7164-- DSDownloader is only getting to line 124 of the file before failing.
OK, we are looking into this as I type this....
johnc
Post by johnc »
The file that was up here before was corrupted, oye. Delete the other one, try this one:
u7164-9t06a.crom
johnc <at> diablosport.com
robbydiesel
Post by robbydiesel »
i am glad i started this thread. when we get this figured out. i will download the program. thanks.
sohfast94
Post by sohfast94 »
Download it above.
sohfast94
Post by sohfast94 »
:crickets:
armentrout2
Post by armentrout2 »
I was able to flash the Predator last night with 9t06a, but have not had a chance to write to the truck yet...
OK, thank you.
