I am buying a used Predator for my 04 Dodge. Should I download the latest update before programming my truck? Do the updates contain all the info from all of the earlier updates? In example: revision 10 includes revision 1,2,3,4...... 10.
Which tune will give me the best fuel mileage?
Also, is there an option to register used Predators? Thanks in advance.
Used Predator Questions
RE: Used Predator Questions
Yes I would definitely load the latest updates.
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
I also have a Quadzilla boost fooler and an adjustable boost elbow that I have never used. Would they help used with the Predator?
2004 (early) Cummins 2500 2wd Quadcab, 5" FBD exhaust, BHAF with heat shield, ISSPRO gauges, Holley Black fuel pump with 1/2" lines and dual Filters, 1.5" front coil levelers, HTS valve body, 3" Intake Elbow
Re: RE: Used Predator Questions
In my opinion, yes. The main thing I would be concerned with is your transmission.dbshelton wrote:I also have a Quadzilla boost fooler and an adjustable boost elbow that I have never used. Would they help used with the Predator?
Yep. I hope I'll be happy with the "Tow Tune" I promise not to do any boosted launches and such.ropnjessi wrote: The main thing I would be concerned with is your transmission.
