car died
kevineugene
car died
Post by kevineugene »
u7146 1998 gt mustang i was rideing down the road and my car stumbled twice and died now it want crank and i plugged the predator in and it said could not recongnize vehicle .
RE: car died
If this happened while simply driving down the road, you need to get this car in to a mechanic to be checked out.
kevineugene
RE: car died
well for what reason would the tuner not recognize my vehicle , and i am a mechanic , c&l ,under drive pulleys 125 zex dry shot
kevineugene
RE: car died
i have power its just the car want start and i cant hear my fuel pump, would this cause the tuner not to recongnize my vehicle
kevineugene
RE: car died
hello
kmac1
RE: car died
Post by kmac1 »
If the Predator was not writing a tune to the car when this happened then there is no way it messed up the PCM. It wasn't even connected by the sound of it. You need to look over the car and do a full diagnosis. Spark, Fuel, etc... the normal no start diagnostic procedure. Maybe just a blown fuse and the PCM lost power.
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
kevineugene
RE: car died
i know this ,after the cat quit i plugged in my tuner to see if there where any codes and when i plug it in it says can not read vehicle info . i was trying to see if there were any trouble codes so i could try to fix it . the tuner will not tell me nothing cuz it says it can not read vehicle info
kevineugene
RE: car died
correction after the car quit
sohfast94
RE: car died
Post by sohfast94 »
Sounds like your PCM just died.
Insert Clever comment here...
kevineugene
RE: car died
the tuner will not do anything , and like i said all i was doing was rideing down the rd and the car died like it ran outa gas , so i pulled it home and hooked my tuner up to see any trouble codes and it says cannot read vehicle info ,
kevineugene
RE: car died
if it died do i get a new what do i have to do
kevineugene
RE: car died
is my tuner no good now tht i have to get a new pcm
kevineugene
RE: car died
can i get one from the junk yard
kevineugene
RE: car died
how do i tell if my pcm is bad i have it out of the vehicle
kevineugene
RE: car died
hello plzzzz help this is my only vehicle
Return to “Predator Ford Gas”
