I took a look at this parameter with the tool.
I cannot tell what the Performance tune settings are with your "basis performance tune.
The choices are:
Abuse mode time limit off/on/no change
% Tq Reduction vs RPM off/on/no change
Upshift Tq reduction off/on/no change
There are no numbers or percents, or slider switches or anything.
Would you please find out for me what the settings are or should be with the Predator performance tune loaded?
How do I confirm that these (Predator performance tune settings) are REALLY installed in the pcm?
Is there any additional adjustment that I can make to boost things a little?
When the torque mgmt systems of the pcm operate, what sensors or parameters TRIGGER the torque management to take place.
Stick shift car!!!!
Thanks.
