Tune will not load in 05 Hemi Ram
kenandjenn
I was able to update my tuner and install the TCM crom just fine. However, the tune will not load.
It keeps telling me to turn the key on/off (three time) and then says make sure key in on. I have the key on, but it says try again.
dodge4x4810
RE: Tune will not load in 05 Hemi Ram
I have the same exact problem. I am glad to see that it is not only me.
kenandjenn
For some reason it is not seeing your key cycles.
Try pausing for a few seconds between cycling on/off and pressing OK.
kenandjenn
OK, I have tried several times to load any tune to my truck and nothing was on except for the ignition, it simply will not load any tune to my truck or complete. The last time I tried it took me four times to load the stock program to the truck thank god it finally aloud me to do that. I'm not sure whats up with this tuner but I loaded SuperChips back in with 87 tune and work fine and ran like a charm. I will not be trying this again anytime soon, I'm afraid at some point it will not reload my stock program and then I will be really screwed.
BMRbrnSNRbrd
I've had the same problem with my '04 Ram Hemi. Every time I attempt to modify the tune (which frankly isn't much as we still can't change shift points) it gets all the way to the end where it asks for you to cycle the key. It asks three times and then aborts...very irritating.
'04 Dodge Ram Hemi QC
Predator U7137, 4.56s,Thorley Tri-Y Headers/Y-Pipe, Magnaflow Muffler & HiFlow Cat, Mark VIII E-Fan, 180 Stat, 8.2mm Wires, NGK 5306 Plugs, C.A.I, Optima Yellowtop, Trans Resistor mod
- chefred112
..same with me...looks like at the point wer alll having this issue is when the Tcm portion tries to load....
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
05 Hemi QCSB
We are testing this in house right now, should have a fix soon.
- chefred112
..not here...just the params I modify will get an asterisk...
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
