Predator Update Info
I have a Predator 7130. If I want to download the latest update, does it contain info from all of the previous earlier dated updates, or do I need to download the earlier updates first to get all of the info?
2004 (early) Cummins 2500 2wd Quadcab, 5" FBD exhaust, BHAF with heat shield, ISSPRO gauges, Holley Black fuel pump with 1/2" lines and dual Filters, 1.5" front coil levelers, HTS valve body, 3" Intake Elbow
RE: Predator Update Info
Not always. I lost a stack tune when I went from r22 to r29 but got them back when I went to 9r03. After I went to 9r03 I added a Puck but couldn't use the stack tunes with 9r03 - technical problems. Now they have 9t04a and it works with the stack tunes. Once you DL the latest rev you can't go back but I don't think it will matter at this date cuz all the feature can be had again, one way or another. It would be a good idea to talk to tech Support or the programmers if you have a rev you really like so you don't take a chance at losing a feature you like.
03, HO, 6sp, 4.10, Predator, A2k turbo, GDP 391, Dual BHAF's, 4" exhaust.
