2008 Ram - Predator does not support?
Ramhemi03
Post by Ramhemi03 »
I have tried several times to hook this up to my truck and i get Predator U7137 does not support
Calid:05094507AH
Tool update might be availeable.
The tool says that I dont need an update??
I got this from the tool
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM8 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '151041241'.
Part number = 'u7137'.
CROM version = 'u7137-9r01 11/11/2008 04:29:51 PM boot3'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Origional backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool SUPPORTS multiple ECUs.
Config does NOT indicate multiple ECUs.
Tool reports 1 ECUs.
Ramhemi03
RE: 2008 Ram - Predator does not support?
Post by Ramhemi03 »
Serial:900b4d9
Part:u7137 u7137
Version:v.9r01
Hardware:UNIV_REV2
Bus:SCI CAN
Born:11/11/2008 7414
Bus test PASSED
No tab or button have emerged when hooked up to my computer saying either calibration update or updater.
Speed1B
Post by Speed1B »
You need to download the revision. 9ro2.
I have an 08 and no problems.
I seem to recall this to be a fairly new calibration for the 08 Rams.
Hopefully we can get the file from Dodges website and get it supported first thing next week.
Ramhemi03
Post by Ramhemi03 »
Truck is brand new got it last month and as for revision 9ro2, I can't seem to find it on the downloads page
07HemiR6
Post by 07HemiR6 »
Ramhemi03 wrote:Truck is brand new got it last month and as for revision 9ro2, I can't seem to find it on the downloads page
Its here: http://www.diablosport.com/index.php?na ... 0086735f8b
07 Ram 1500 QCSB Sport 4x4 Hemi
TTI Headers, y-pipe w/ high flow cats, Magnaflow Cat Back
00pumpkin
Post by 00pumpkin »
Mine is saying the same thing. I have the updated version in it and a re-calibration tab did not pop up in the DS downloader so I assume that it thinks I dont need one. Is there a fix for this? Did it not get tested on 08's??
johan
Post by johan »
There is a new update for the 08's and 04's that came out recently, we are working on adding them in, should get added in this week.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Ramhemi03
Post by Ramhemi03 »
Would an aftermarket remote starter cause this issue also??
johan
Post by johan »
Ramhemi03 wrote:Would an aftermarket remote starter cause this issue also??
It does cause issues yes, but not the one you are seeing, you have a new pcm update from dodge that we do not support yet as it is very new.
Diablosport INC
~RAM~
Post by ~RAM~ »
What would remote start mess with?
The wife is gettin me one for christmas. Should I tell her nevermind?
2005 Ram 1500 QC 5.7.
K&N cold air intake, LT headers, 2.5" true dual exaust with no cats...
00pumpkin
Post by 00pumpkin »
I have a factory remote start and still get the same message..........
I just bought my truck back in September. I guess it must have the newest update.
johan
Post by johan »
Remote starts (some) mess with the key on/off settings, but most people who have them and predator just disable it while programming.
Diablosport INC
Quick
Post by Quick »
Especially aftermarket car alarms, and I guess remote starters, can/will effect tuning the car. If there's problems it seems to happen when you try to download a tune or changes to the car. So it hangs or fails to download a tune/change. I've never heard of anything getting screwed up but it just doesn't do the download to the car. A calid problem is different and means that the predator is talking to the PCM just fine but it's detected a "version mismatch" between the PCM image and the Predator version.
I have to disconnect (pull the fuse) on my aftermarket car alarm to tune my car. I can hook up the predator and do logging just fine but if I want to download a tune or quick adjust changes I have to disconnect my car alarm first.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Speed1B
Post by Speed1B »
I have an 08 and everything works great. I downloaded the rev 02 before i even used it.
Unbelievible how good my truck runs now. Night and day difference and gas mileage didnt change.
Are there any tweaks coming soon Diablo staff? I mean are we taking baby steps into this here or do we have the best we are gonna get?
