04 srt 4 Knock Retard
theathleteih
Post by theathleteih »
u7134
9.10r
04 dodge srt4
Im getting KR (-6) at wot in the 4500-6800 rpm range. Afr 11.8- 12.2
running a GT2871R 23 PSI
91 cali oct
sohfast94
RE: 04 srt 4 Knock Retard
Post by sohfast94 »
What's your ACT?
What plugs/gap?
Care to include a log?
Insert Clever comment here...
What brand of fuel as well?
Fuel quality will have a major impact on the resistance to KR, especially with what passes as 91 octane out there sometimes.
theathleteih
brand of fuel is cheveron, shell, and one 76 staion that works.
my plugs are autolite xp's gap .38
I thaught I Logged the ACT but its not there.
what all do you want me to log then I can post
the car pulls major style and it feels ok. since the predator install it has 10x better drivability so could it be false? and should i pull timing?
im down loading the 9r.11 now
sohfast94
Post by sohfast94 »
Just ACT, RPM, PRATIO, Spark CYL1, ECT, MPH
theathleteih
will have it up about 6pm pacific time. work calls
theathleteih
I dont know if it me my comp or what but how do I post my log
goats-srt
Post by goats-srt »
theathleteih wrote:I dont know if it me my comp or what but how do I post my log
just email bryan
but where was your timing at cause with the 2871 and piss gas at 23psi with no meth your timing should be around 19-22 deg to be safe and u might have to load it as a Attachment on here
theathleteih
just email bryan
That would be sprk adjment on the loger right.
theathleteih
here is my log
goats-srt
Post by goats-srt »
the timing looks alittle high to me take out like 3 deg
theathleteih
at that rpm range. or all the rpms
28patrick28
Post by 28patrick28 »
Maybe just try to add gaz first, you seem to run learn , Specially with 23 psi of boost ..... Its there a 91 oct tune? i think we only have a 93 oct tune, so be sure to run 93 oct at least.... Im gonna send you a log 91 oct gaz running in 93 perf tune, i was getting about the same knock than you at 17-18 psi only (4500 to 6000) so i think we really need 93 oct gaz for this tune .....
sohfast94
Post by sohfast94 »
Just take out 2-3degrees... I don't know where you're located so it's hard to guess the quality of your gas...
sohfast94
Post by sohfast94 »
28patrick28 wrote:Maybe just try to add gaz first, you seem to run learn , Specially with 23 psi of boost ..... Its there a 91 oct tune? i think we only have a 93 oct tune, so be sure to run 93 oct at least.... Im gonna send you a log 91 oct gaz running in 93 perf tune, i was getting about the same knock than you at 17-18 psi only (4500 to 6000) so i think we really need 93 oct gaz for this tune .....
do you have a wideband in your car?
