Tune will not load in 05 Hemi Ram
kenandjenn
Post by kenandjenn »
I was able to update my tuner and install the TCM crom just fine. However, the tune will not load.
It keeps telling me to turn the key on/off (three time) and then says make sure key in on. I have the key on, but it says try again.
dodge4x4810
RE: Tune will not load in 05 Hemi Ram
Post by dodge4x4810 »
I have the same exact problem. I am glad to see that it is not only me.
kenandjenn
I'm gonna try to drive it after it fails to load. Someone else got it to work doing that.
For some reason it is not seeing your key cycles.
Try pausing for a few seconds between cycling on/off and pressing OK.
kenandjenn
I tried that and it did not work. It will write to the PCM, but now fails after that. It says that one part of the tune fails.
I have returned the truck back to stock and will await further advice.
~RAM~
Post by ~RAM~ »
It did it for me an told me to unplug the pred an I rebooted an went to the tune an installed again an everything went fine.
2005 Ram 1500 QC 5.7.
K&N cold air intake, LT headers, 2.5" true dual exaust with no cats...
gomango
Post by gomango »
OK, I have tried several times to load any tune to my truck and nothing was on except for the ignition, it simply will not load any tune to my truck or complete. The last time I tried it took me four times to load the stock program to the truck thank god it finally aloud me to do that. I'm not sure whats up with this tuner but I loaded SuperChips back in with 87 tune and work fine and ran like a charm. I will not be trying this again anytime soon, I'm afraid at some point it will not reload my stock program and then I will be really screwed.
BMRbrnSNRbrd
Post by BMRbrnSNRbrd »
I've had the same problem with my '04 Ram Hemi. Every time I attempt to modify the tune (which frankly isn't much as we still can't change shift points) it gets all the way to the end where it asks for you to cycle the key. It asks three times and then aborts...very irritating.
'04 Dodge Ram Hemi QC
Predator U7137, 4.56s,Thorley Tri-Y Headers/Y-Pipe, Magnaflow Muffler & HiFlow Cat, Mark VIII E-Fan, 180 Stat, 8.2mm Wires, NGK 5306 Plugs, C.A.I, Optima Yellowtop, Trans Resistor mod
johan
Post by johan »
We are aware of this issue and working on a fix for it.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
whitehemi
Post by whitehemi »
My Diablo says the same thing but it does it load if I go back and check. it also shows up on the truck. Although I would like to be able to complete the process via the Diablo's commands....
chefred112
Post by chefred112 »
..same with me...looks like at the point wer alll having this issue is when the Tcm portion tries to load....
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
We are testing this in house right now, should have a fix soon.
johan
Post by johan »
Curious have you guys seen when you modify the params that all the params gets and asterisk ? Anyone ever see that?
Diablosport INC
chefred112
..not here...just the params I modify will get an asterisk...
-Fast Freddie-
05 Hemi QCSB
BETHALHEMI
Post by BETHALHEMI »
What he said.
