u7194 questions (for 2007 avalanche)
djerome
Post by djerome »
Hello, I'm considering purchasing a u7194 for my 2007 avalanche 5.3(vin#3)
from reading through the posts on here I see that there are no user options in it yet to disable tourque management but I do have a couple questions about the tunes.
do they do the following things I'm looking for.
1)reduce the Power Enrichment delay( time it akes to go from closed to open loop on a WOT start) from the stock 4 seconds to 0
2) remove abuse mode from the torque management
3) reduce all other TM by at least 50% or more
4)reduce the shift lag on the 1-2 shift
5) raise the shift points and shift firmness
6)remove the top speed limiter.
thanks
Derek ......
RE: u7194 questions (for 2007 avalanche)
I don't believe there is tranny support for that model yet (just like mine :cry: ), so none of the shifting or tranny TM will be addressed right now. But it does remove some of the engine TM, speed limiter, and reduces the PE delay.
Re: u7194 questions (for 2007 avalanche)
djerome wrote:Hello, I'm considering purchasing a u7194 for my 2007 avalanche 5.3(vin#3)
thanks
Derek ......
1.Yes
2.Just enough to keep it out of your way
3."
4.No shifting changes are made, but the reduced TM will provide better shift feel/performance.
5.Not yet, coming in the future
6.Yes
Return to “Predator GM Gas”
