PCM stage 2 or Stock PCM!? Need advise!
jam89si
Post by jam89si »
Hey guy's!!
Here's my plan!! I have a 05 Nsrt4!!
-Ported Exhaust Manifold with 38mm external wastegate
-Stock Turbo for now!
-3" MPX Turboback (02 housing, DP, catback...)
-MPX FMIC
-Mopar CAI
-Stage 2 injector
-3Bar Tip&Map ( from stage 2... )
NOW!!
I am planing to buy the Predator!!
Should I buy a Stage 2 PCM or my stock PCM will be fine??
I know the Stock PCM is not supposed to be used with 3Bar Tip&Map Sensor!! But I guess that could be resolved with a BaseMap from Diablosport??I'll probably need a wideband to!!!
Need your help guys!!
:D
RE: PCM stage 2 or Stock PCM!? Need advise!
Should be no need for the StageII PCM.
Let us know when you get the file and Brian will set you up with a tune for the MAP and Tip sensors.
jam89si
Post by jam89si »
Perfect thanks alot!!
After I guess I'll have to go on the dyno to do a fine tuning!?!
Or the map that i'll get from Brian will be ok?
Thanks again!!
Fine tuning would be suggested once you get the base map.
sohfast94
Re: RE: PCM stage 2 or Stock PCM!? Need advise!
Post by sohfast94 »
jam89si wrote:Perfect thanks alot!!
Thanks again!!
It will probably need a little adjustment.. Make sure you have a wideband AFR
Insert Clever comment here...
jam89si
RE: Re: RE: PCM stage 2 or Stock PCM!? Need advise!
Post by jam89si »
Yeah I'll get one!! Thanks!! And i'll go on the dyno after!!
And just to make sure, I should be able to get at least the same power or more from my stock pcm with your custom map (stg2 inject, 3Bar Tip&Map, external WG) than with the stage 2 PCM + Diablosport stg2 base map?
28patrick28
Post by 28patrick28 »
You gonna have more power for sure, because the stage 2 computer dont know you have a Ported Exhaust Manifold. You gonna like it so much Trust me. and you have already 3 bar map sensor to read more than 18.5 psi. like the stock 2.25 bar. You dont have the risk than the ecu pull timing like crazy.
Brian is a good tuner , you gonna get good after sale service with him too.
T
AltersEgo
Re: RE: Re: RE: PCM stage 2 or Stock PCM!? Need advise!
Post by AltersEgo »
28patrick28 wrote:You gonna have more power for sure, because the stage 2 computer dont know you have a Ported Exhaust Manifold. You gonna like it so much Trust me. and you have already 3 bar map sensor to read more than 18.5 psi. like the stock 2.25 bar. You dont have the risk than the ecu pull timing like crazy.
T
Brian is an excellent tuner. He fixed me up. The place I bought the predator from couldn't get my tune working since October.
