GM CODES
Moderators: mikel, 06MonteSS
RE: code p1514
been seein' those ones yourselves quite a bit lately have ya???
:lol: :lol:
sorry, couldn't resist...
hahahaha!!
RE: code p1514
LOL, douchenozzle....
tech@diablosport.com
RE: code p1514
:lol: :lol: !!!
gump2388
RE: code p1514
Post by gump2388 »
any updates on the 9r06 locking the ecm. i know yall are prolly still working. but i didnt know if u had anything going yet.
RE: code p1514
DTC DTC Descriptor Module That Sets the DTC Diagnostic Procedure
B0012 Passenger Frontal Deployment Loop Stage 2 Resistance Low SDM DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0013 Passenger Frontal Deployment Loop Stage 2 Open SDM DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0014 Passenger Frontal Deployment Loop Stage 2 Voltage Out of Range SDM DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0016 Passenger Frontal Deployment Loop Stage 1 Resistance Low SDM DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0017 Passenger Frontal Deployment Loop Stage 1 Open SDM DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0018 Passenger Frontal Deployment Loop Stage 1 Out of Range SDM DTC B0012, B0013, B0014, B0016, B0017, or B0018
B0022 Driver Frontal Deployment Loop Stage 1 Resistance Low SDM DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0024 Driver Frontal Deployment Loop Stage 1 Out of Range SDM DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0026 Driver Frontal Deployment Loop Stage 1 Open SDM DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0042 Driver Frontal Deployment Loop Stage 2 Resistance Low SDM DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0043 Driver Frontal Deployment Loop Stage 2 Voltage Out of Range SDM DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0044 Driver Frontal Deployment Loop Stage 2 Open SDM DTC B0022, B0024, B0026, B0042, B0043, or B0044
B0051 Deployment Commanded SDM DTC B0051
B0053 Deployment Commanded with Loop DTCs Present SDM DTC B0053
B0078 Passenger Side Impact Sensor (SIS) Performance SDM DTC B0078, B0081, or B0082
B0081 Incorrect Passenger Side Impact Sensor (SIS) Installed SDM DTC B0078, B0081, or B0082
B0082 Discard Passenger Side Impact Sensor (SIS) SDM DTC B0078, B0081, or B0082
B0083 Passenger Seat Position Sensor Circuit SDM DTC B0083 or B0084
B0084 Driver Seat Position Sensor Circuit SDM DTC B0083 or B0084
B0090 Active Switch Voltage Out of Range SDM DTC B0090
B0091 Active Switch: Wrong State SDM DTC B0091
B0092 Passenger Presence System Performance SDM DTC B0092
B0098 Passenger Presence System Configuration Error SDM DTC B0098
B0100 Electronic Front End Sensor 1 Performance SDM DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0101 Discard Electronic Front End Sensor 1 SDM DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0102 Incorrect Electronic Front End Sensor 1 Installed SDM DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0103 Electronic Front End Sensor 2 Performance SDM DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0104 Discard Electronic Front End Sensor 2 SDM DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0105 Incorrect Electronic Front End Sensor 2 Installed SDM DTC B0100, B0101, B0102, B0103, B0104, or B0105
B0159 Outside Air Temperature Sensor Circuit Range/Performance HCM DTC B0159
HVAC Control Module DTC B0159 or B0164
B0164 Passenger Compartment Temperature Sensor Circuit Range/Performance HVAC Control Module DTC B0159 or B0164
B0174 Output Air Temperature Sensor 1 Upper Left Circuit Range/Performance HVAC Control Module DTC B0174, B0179, B0510, or B0515
B0179 Output Air Temperature Sensor 2 Lower Left Circuit Range/Performance HVAC Control Module DTC B0174, B0179, B0510, or B0515
B0183 Solar Load Sensor 1 Circuit HVAC Control Module DTC B0183 or B0188
B0188 Solar Load Sensor 2 Circuit HVAC Control Module DTC B0183 or B0188
B0229 Recirculate Position Feedback Circuit Range/Performance HVAC Control Module DTC B0229, B0414, B0424, or B3770
B0263 Air Flow Control 6 A/C Circuit HVAC Control Module DTC B0263, B0268, B0408, or B0418 for the automatic systemor
DTC B0263, B0408, or B0418 for the manual system
B0268 Air Flow Control 7 Circuit HVAC Control Module DTC B0263, B0268, B0408, or B0418
B0283 Electric Rear Defrost Circuit BCM DTC B0283
B0408 Temperature Control 1 Circuit HVAC Control Module DTC B0263, B0268, B0408, or B0418 for the automatic systemor
B0414 Temperature Control 1 Feedback Circuit Range/Performance HVAC Control Module DTC B0229, B0414, B0424, or B3770 for the automatic systemor
DTC B0414, B0424, or B3770 for the manual system
B0418 Temperature Control 2 Circuit HVAC Control Module DTC B0263, B0268, B0408, or B0418 for the automatic systemor
B0424 Temperature Control 2 Feedback Circuit Range/Performance HVAC Control Module DTC B0229, B0414, B0424, or B3770 for the automatic systemor
B0510 Output Air Temperature Sensor 3 Upper Right Circuit Range/Performance HVAC Control Module DTC B0174, B0179, B0510, or B0515
B0515 Output Air Temperature Sensor 4 Lower Right Circuit Range/Performance HVAC Control Module DTC B0174, B0179, B0510, or B0515
B0540 Speedometer Circuit IPC DTC B0540
B0560 Tachometer Circuit IPC DTC B0560
B0790 Transfer Case Neutral Indicator Circuit Malfunction ATC DTC B0790 for the NVG 246-NP8 transfer caseor
DTC B0790 for the NVG 263-NP1 transfer case
B0989 Output Air Temperature Lower Sensors Correlation HVAC Control Module DTC B0989
B0990 Output Air Temperature Upper Sensors Correlation HVAC Control Module DTC B0990
B1000 Electronic Control Unit (ECU) Performance Audio Amplifier, BCM, DDM, DRR, DSM, FPDM, HVAC, IPC, Radio, RWSCM, SDM, VCIM DTC B1000
B1001 Option Configuration Error Radio DTC B1001
SDM DTC B1001
VCIM DTC B1001
B1004 Keep Alive Memory (KAM) Reset OnStar® VCIM DTC B1004
B1007 EEPROM Write Error OnStar® VCIM DTC B1007
B1009 EEPROM Checksum Mismatch OnStar® VCIM DTC B1009
B1017 Output Driver Module Performance BCM DTC B1017 or B3970
B1023 Integral Switch Performance DDM, PDM DTC B1023
B1025 Audio Output 1 Left Front Circuit Radio DTC B1025, B1035, B1045, or B1055
B1035 Audio Output 2 Right Front Circuit Radio DTC B1025, B1035, B1045, or B1055
B1045 Audio Output 3 Left Rear Circuit Radio DTC B1025, B1035, B1045, or B1055
B1055 Audio Output 4 Right Rear Circuit Radio DTC B1025, B1035, B1045, or B1055
B1235 Amplifier On Signal Circuit Radio DTC B1235
B1259 Antenna Ground Circuit DRR DTC B1259
B1372 Device Ignition 1 Circuit Low BCM DTC B1372
B1375 Device Ignition 3 Circuit HVAC Control Module DTC B1375 with CJ2or
DTC B1375 with CJ3
B1390 Device Voltage Reference Input 1 Circuit GBCM DTC B1390
B1397 Device Voltage Reference Output Circuit Low BCM DTC B1397
B139A DC/AC Converter Input Voltage Low SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B139B DC/AC Converter Current Sensor Low SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B139C DC/AC Converter Current Sensor High SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B139D DC/AC Converter Output Current High SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B139E DC/AC Converter Stuck OFF SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B139F DC/AC Converter Stuck ON SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B140A DC/AC Converter Output Ground Fault Performance SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B140B DC/AC Converter Output Ground Fault SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B140C DC/AC Converter Performance SGCM DTC B139A, B139B, B139C, B139D, B139E, B139F, B140A, B140B, or B140C
B1422 Device Power Moding Error HCM DTC B1422
B1440 Power Mode Master Input Circuits Mismatch BCM DTC B1440
B1480 Battery Rundown Protection Circuit BCM DTC B1480
B1487 Generator L-Terminal Circuit Low GBCM DTC B1487
B1488 Generator L-Terminal Circuit High GBCM DTC B1488
B1492 Generator F-Terminal Circuit Low GBCM DTC B1492
B1516 Battery Current Sensor Performance GBCM DTC B1516
B1544 Mirror Motors Common Circuit DDM, PDM DTC B1544, B1600, or B1605
B1580 Left Front Mirror Horizontal Position Sensor Circuit DDM, PDM DTC B1580, B1590, B1610, or B1620
B1590 Left Front Mirror Vertical Position Sensor Circuit DDM, PDM DTC B1580, B1590, B1610, or B1620
B1600 Mirror Motor Vertical Circuit DDM, PDM DTC B1544, B1600, or B1605
B1605 Mirror Motor Horizontal Circuit DDM, PDM DTC B1544, B1600, or B1605
B1610 Right Front Mirror Horizontal Position Sensor Circuit DDM, PDM DTC B1580, B1590, B1610, or B1620
B1620 Right Front Mirror Vertical Position Sensor Circuit DDM, PDM DTC B1580, B1590, B1610, or B1620
B1640 Left Front Mirror Heater Circuit DDM, PDM DTC B1640 or B1645
B1645 Right Front Mirror Heater Circuit DDM, PDM DTC B1640 or B1645
B1722 Mirror Power Fold Control Circuit DDM, PDM DTC B1722
B1770 Driver Seat Motor Horizontal Circuit DSM DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1775 Driver Seat Motor Front Vertical Circuit DSM DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1780 Driver Seat Motor Rear Vertical Circuit DSM DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1785 Driver Seat Motor Recline Circuit DSM DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1790 Driver Seat Motor Lumbar Circuit DSM DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1805 Driver Seat Motor Side Bolster Circuit DSM DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 Driver Seat Recline Position Sensor Circuit DSM DTC B1825
B1850 Driver Seat Lumbar Position Sensor Circuit DSM DTC B1850, B1860, B1960, B2355, B2365, or B2375
B1960 Driver Seat Side Bolster Position Sensor Circuit DSM DTC B1850, B1860, B1960, B2355, B2365, or B2375
B2355 Driver Seat Front Vertical Position Sensor Circuit DSM DTC B1850, B1860, B1960, B2355, B2365, or B2375
B2365 Driver Seat Rear Vertical Position Sensor Circuit DSM DTC B1850, B1860, B1960, B2355, B2365, or B2375
B2375 Driver Seat Horizontal Position Sensor Circuit DSM DTC B1850, B1860, B1960, B2355, B2365, or B2375
B2425 Driver Seat Heater Circuit DSM DTC B2425 or B2430
B2430 Passenger Seat Heater Circuit DSM DTC B2425 or B2430
B2435 Driver Seat Back Heater Sensor Circuit DSM DTC B2435 or B2440
B2440 Passenger Seat Back Heater Sensor Circuit DSM DTC B2435 or B2440
B2455 Cellular Phone Microphone Circuit Malfunction OnStar® VCIM DTC B2455
B2470 Cellular Phone Antenna Circuit Malfunction OnStar® VCIM DTC B2470
B2476 Cellular Phone Select Service Switch Malfunction OnStar® VCIM DTC B2476
B2482 Cellular Phone Select Switch Range/Performance OnStar® VCIM DTC B2482
B2483 GPS Sensor Circuit Low OnStar® VCIM DTC B2483 or B2484
B2484 GPS Sensor Circuit Open OnStar® VCIM DTC B2483 or B2484
B2527 Front Foglamps Circuit Low BCM DTC B2527
B2537 Rear Foglamps Circuit Low BCM DTC B2537
B2550 Backup Lamps Control Circuit BCM DTC B2550
B2575 Headlamp Control Circuit BCM DTC B2575
B2580 Headlamp High Beam Control Circuit BCM DTC B2580
B2585 Park Lamp Control Circuit BCM DTC B2585
B2600 Daytime Running Lamp Control Circuit BCM DTC B2600
B2610 Passenger Compartment Dimming 1 Circuit BCM DTC B2610
B2615 Passenger Compartment Dimming 2 Circuit BCM DTC B2615
B2620 Display Dimming Pulse Width Modulation (PWM) Input Circuit BCM DTC B2620
B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit BCM DTC B2625
B2645 Ambient Light Sensor Circuit BCM DTC B2645
B2725 Active Transfer Case (ATC) Mode Switch Circuit Malfunction ATC DTC B2725 for the NVG 246-NP8 transfer caseor
DTC B2725 for the NVG 263-NP1 transfer case
B2752 Horn Relay Coil Circuit Low BCM DTC B2752
B2815 Steering Wheel Controls Illegal Resistance Value BCM DTC B2815 or
DTC B2815
B2947 Security System Sensor Power Circuit Low BCM DTC B2947
B2948 Security System Sensor Power Circuit High BCM DTC B2948
B2957 Security System Sensor Data Circuit Low BCM DTC B2957
B2958 Security System Sensor Data Circuit High BCM DTC B2958
B2960 Security System Sensor Data Incorrect but Valid BCM DTC B2960
B2961 Key in Ignition Circuit BCM DTC B2961
B3006 Hood Ajar Circuit BCM DTC B3006
B3008 Hood Ajar Circuit Low BCM DTC B3008
B3009 Hood Ajar Circuit High BCM DTC B3009
B3031 Security System Controller in Learn Mode BCM DTC B3031
B3033 Security System Indicates Tamper BCM DTC B3033
B3654 Electrical Power Take Off Control Switch Circuit HCM DTC B3654, B3655 or B3656
B3655 Electrical Power Take Off Control Switch Circuit Low HCM DTC B3654, B3655 or B3656
B3656 Electrical Power Take Off Control Switch Circuit High HCM DTC B3654, B3655 or B3656
B3770 Air Flow Control 6 Feedback Circuit HVAC Control Module DTC B0229, B0414, B0424, or B3770 for the automatic systemor
B3801 Passenger Compartment Lamp Request Circuit BCM DTC B3801
B3802 Parklamp Request Circuit BCM DTC B3802
B3808 Rear Door Lock Relay Circuit BCM DTC B3808
B3809 Rear Door Unlock Relay Circuit BCM DTC B3809
B3819 Left Rear Window Up Control Circuit BCM DTC B3819
B3820 Left Rear Window Down Control Circuit BCM DTC B3820
B3821 Left Rear Window Relay Power Circuit BCM DTC B3821
B3822 Right Rear Window Up Control Circuit BCM DTC B3822
B3823 Right Rear Window Down Control Circuit BCM DTC B3823
B3824 Right Rear Window Relay Power Circuit BCM DTC B3824
B3844 Engine Coolant Circulation Pump Circuit HCM DTC B3844
B3941 Front Seat Heaters Circuit DSM DTC B3941
B3962 Seat Motors Overcurrent DSM DTC B3962
C0035 Left Front Wheel Speed Sensor Circuit EBCM DTC C0035 or C0040 or
DTC C0035 or U0415
C003D Rear Wheel Speed Sensor Circuit (PHT) EBCM DTC C0055 or C003D
C0040 Right Front Wheel Speed Sensor Circuit EBCM DTC C0035 or C0040
C0055 Rear Wheel Speed Sensor Circuit EBCM DTC C0055 or C003D
C0078 Wheel Speed Sensor Frequency Error (PHT) EBCM DTC C0245 or C0078
C0110 Pump Motor Circuit EBCM DTC C0110
C0136 Base Brake System Pressure Circuit EBCM DTC C0136
C0161 Antilock Brake System (ABS)/Traction Control System (TCS) Brake Switch EBCM DTC C0161
C0201 Antilock Brake System (ABS) Enable Relay Contact Circuit EBCM DTC C0201
C0221 Right Front Wheel Speed Sensor Circuit Open EBCM DTC C0221-C0227 or C021
C0222 Right Front Wheel Speed Signal Missing EBCM DTC C0221-C0227 or C021
C0223 Right Front Wheel Speed Signal Erratic EBCM DTC C0221-C0227 or C021
C0225 Left Front Wheel Speed Sensor Circuit Open EBCM DTC C0221-C0227 or C021
C0226 Left Front Wheel Speed Signal Missing EBCM DTC C0221-C0227 or C021
C0227 Left Front Wheel Speed Signal Erratic EBCM DTC C0221-C0227 or C021
C0228 Left Front Antilock Brake System (ABS) Channel in Release Too Long EBCM DTC C0228
C0229 Drop Out of Both Front Speed Sensors EBCM DTC C0229 or C029
C0235 Rear Wheel Speed Signal Circuit Open EBCM DTC C0235-C0237 or P0609
C0236 Rear Wheel Speed Signal Circuit Missing EBCM DTC C0235-C0237 or P0609
C0237 Rear Wheel Speed Signal Circuit Erratic EBCM DTC C0235-C0237 or P0609
C0238 Wheel Speed Mismatch EBCM DTC C0238 or C038
C0240 EBCM Malfunction EBCM DTC C0240
C0241 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0242 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0243 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0244 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0245 EBCM Control Valve Circuit - Less than 8600 GVWR or equipped with Rear Disc Brakes EBCM DTC C0241-C0254 or C041-C054
Wheel Speed Sensor Frequency Error - Greater than 8600 GVWR or equipped with Rear Drum Brakes DTC C0245 or C0078
C0246 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0247 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0248 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0251 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0252 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0253 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0254 EBCM Control Valve Circuit EBCM DTC C0241-C0254 or C041-C054
C0265 EBCM Motor Relay Circuit EBCM DTC C0265 or C0266 and C065 or C066
C0266 EBCM Motor Relay Circuit EBCM DTC C0265 or C0266 and C065 or C066
C0267 Pump Motor Circuit Open EBCM DTC C0267 or C0268 and C067 or C068
C0268 Pump Motor Circuit Shorted EBCM DTC C0267 or C0268 and C067 or C068
C0269 Excessive Dump Time EBCM DTC C0269 or C0274 and C069 or C074
C0271 EBCM Malfunction EBCM DTC C0271-C0273, C0284
C0272 EBCM Malfunction EBCM DTC C0271-C0273, C0284
C0273 EBCM Malfunction EBCM DTC C0271-C0273, C0284
C0274 Excessive Isolation Time EBCM DTC C0269 or C0274 and C069 or C074
C0277 Brake Pedal Position Sensor Circuit EHPS DTC C0277
C0278 Brake Pedal Position Sensor Not Calibrated EHPS DTC C0278
C0279 Powertrain Configuration not Valid EBCM DTC C0279
C0281 Stoplamp Switch Circuit EBCM DTC C0281 or C081
C0282 Brake Pedal Position Sensor Circuit Range/Performance EHPS DTC C0282
C0283 Brake Pedal Position Sensor Circuit Low EHPS DTC C0283
Mode Switch Circuit Malfunction EBCM DTC C0283
C0284 Brake Pedal Position Sensor Circuit High EHPS DTC C0284
C0287 Delivered Torque Signal Malfunction EBCM DTC C0287, P1644, or P1689
C0290 Class 2 Data Link Malfunction EBCM DTC C0290 or C0292
C0291 Body Control Module (BCM) Configuration not Valid EBCM DTC C0291
C0292 Lost Communications with Engine Control System EBCM DTC C0290 or C0292
C0294 Brake Switch and Brake Pedal Position Sensor Correlation EHPS DTC C0294
C0297 Powertrain Configuration Data not Received EBCM DTC C0297
C0298 Powertrain Control Malfunction EBCM DTC C0298 or P0856
C0300 Rear Propshaft Speed Sensor Malfunction ATC DTC C0300
C0305 Front Propshaft Speed Sensor Malfunction ATC DTC C0305
C0306 Motor A or B Circuit Malfunction ATC DTC C0306 for the NVG 246-NP8 transfer caseor
DTC C0306 for the NVG 263-NP1 transfer case
C0321 Transfer Case Lock Circuit Malfunction ATC DTC C0321
C0327 Encoder Circuit Malfunction ATC DTC C0327 for the NVG 246-NP8 transfer caseor
DTC C0327 for the NVG 263-NP1 transfer case
C0359 Four Wheel Drive Low Range (4WD low) Discrete Output Circuit Malfunction ATC DTC C0359 for the NVG 246-NP8 transfer caseor
DTC C0359 for the NVG 263-NP1 transfer case
C0374 General System Malfunction ATC DTC C0374
C0379 Front Axle System Malfunction ATC DTC C0379 for the NVG 246-NP8 transfer caseor
DTC C0379 for the NVG 263-NP1 transfer case
C0448 Electric Hydraulic Steering Pump Enable Circuit EHPS DTC C0448
C0481 Electric Hydraulic Steering Motor Circuit Range/Performance EHPS DTC C0481
C0485 Electric Hydraulic Steering Temperature Sensor Circuit EHPS DTC C0485
C0511 Steering Position and Rate of Change Sensor Circuit EHPS DTC C0511
C0544 Steering Position Sensor Data Error EHPS DTC C0544
C0550 Electronic Control Unit (ECU) Performance ATC DTC C0550 for the NVG 246-NP8 transfer caseor
DTC C0550 for the NVG 263-NP1 transfer case
EBCM DTC C0550 or C0570
EHPS DTC C0550
C0558 Calibration Data Not Programmed EBCM DTC C0558
C0564 Program Read Only Memory (ROM) Checksum Error EHPS DTC C0564
C0570 Electronic Control Unit Performance EBCM DTC C0550 or C0570
C0750 Left Front Low Tire Pressure Sensor PDM, RCDLR DTC C0750, C0755, C0760, or C0765
C0755 Right Front Low Tire Pressure Sensor PDM, RCDLR DTC C0750, C0755, C0760, or C0765
C0760 Left Rear Low Tire Pressure Sensor PDM, RCDLR DTC C0750, C0755, C0760, or C0765
C0765 Right Rear Low Tire Pressure Sensor PDM, RCDLR DTC C0750, C0755, C0760, or C0765
C0775 Low Tire Pressure System Sensors Not Programmed/Learned PDM, RCDLR DTC C0775
C0870 Device Voltage Reference Output Circuit EHPS DTC C0870
C0895 Device Voltage EHPS DTC C0895
Ill_Born_SS
RE: code p1514
Post by Ill_Born_SS »
Due to the ever changing list of DTCs and there definition, here is an update:
There are two kinds of DTCs: Generic and Manufacturer Specific DTCs. Generic DTC is used by all manufacturers and manufacturer specific DTC is for a specific make.
Just enter your code in the search box and read for your vehicles translation.
http://www.aboutautomobile.com/DTC
" Just Friggin Wicked"
Now with TCM support...
CARGUY50@JUNO.COM
? Diablo sport mod U7194 how to turn off AFM
Post by CARGUY50@JUNO.COM »
i received my U7194 from ADM performance 2 days ago. Andy told me it would turn off the AFM. he said he uploaded the software before he shipped it to me. i specifically told the only reason i wanted it was so i could turn off the AFM. well, here is the message from the Diablo" parameters are not available for this vehicle transmission combination 2 " by now i am moderately pissed.i also did not receive a patch cord to connect to the diablo. i went to radio shack. bought the cord for $43 came home and trird to down load from the web site.this down load format is not supported by my XP operating system. now I am really pissed.Andy says it is out of his hands. I have to contact diablo which is closed on weekends. now i am furious. I am ready to smash this f****ng thing against the wall. all I want is for it to turn off the AFM. please give me a solution.
RE: ? Diablo sport mod U7194 how to turn off AFM
yeah... they shouldn't have updated it, cuz there's an issue with the current revision, and with the latest GM flash update that sounds like was done to your car... it's not a recognized calibration id yet...
will have to wait for a new update from diablo...
CARGUY50@JUNO.COM
if i had known they were so unreliable, i never would have bought the piece of SHIT. Thanks ANDY, you really should have better product knowledge. i will be sending the MF back to him.
