my predator does not work
bigred01
Post by bigred01 »
i had the 100 setting on for about a month an now when i plug in the predator to change it nothing happens ...really need to change the program
jbeasts10
RE: my predator does not work
Post by jbeasts10 »
Do you mean ,the programmer will not power up?Or you simply cannot change any of the settings?If it will not power up ,check the fuse for your cig lighter...it also powers the supply line for the obdII port.Hope this helps.
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
bigred01
Post by bigred01 »
ok thnx
