U7191 Goof up!
nsxttt
U7191 Goof up!
Post by nsxttt »
I really need help!
I updated my U7191 for my 05 Vette and I didn't return the tune to stock before I did the update! I do have my stock tune saved on my laptop.
Is there anyway I can get my stock tune back on the Predator?
RE: U7191 Goof up!
import it as a custom tune... then install the custom tune to your car... when you go to install it, the Predator will show Custom Tune instead of Performance tune...
anyway, so import it as a custom tune, then install the custom tune to your car (which is actually your original backup tune). Now your car has the original backup back in it.
Then, under the custom tune menu, you can select "erase custom tune". this will remove it from the predator. then run the U7191 update on the predator again. Now, go install a Performance Tune on your car, and it should backup the original tune to the predator again and you're all set.
RE: U7191 Goof up!
No, no need to do that.....call me at the office with the tool powered up and I'll force the stock tune back to the car.
nsxttt
Re: RE: U7191 Goof up!
Post by nsxttt »
mikel wrote:No, no need to do that.....call me at the office with the tool powered up and I'll force the stock tune back to the car.
I tried that with someone at your office a few weeks ago.
I'll give you a buzz tomorrow!
