6.0L slipping tranny
lrklyne
Post by lrklyne »
Has anyone had problems with tranny slipping? When i have the tune installed my tranny will slip going into 2nd and 3rd. I am really worried because its a fairly new tranny and dont wanna have to replace it AGAIN.
sohfast94
RE: 6.0L slipping tranny
Post by sohfast94 »
What's your calid?
Insert Clever comment here...
lrklyne
Post by lrklyne »
My calid is VZBC9N8
lrklyne
Post by lrklyne »
It actually slips going into 3rd and 4th not 2nd and 3rd
2004 F-350 Super duty Lariat. AFE intake, 4" tubro back, 6" lift, 35x12.5R16 Mickey thompsons.
sohfast94
Post by sohfast94 »
Waht tune are you using?
He said any of the tunes are doing it....
lrklyne
Post by lrklyne »
They all make it slip. Its worse in 100hp. I talked to a tranny guy and he did a scan on my truck and didnt pull any codes. When i spoke to mike i mentioned that the tranny only has 40000 km on it.
lrklyne
Post by lrklyne »
Any thoughts?
sohfast94
Post by sohfast94 »
What gear do you ahve in the truck?
lrklyne
Post by lrklyne »
3.73 Gears. It doesn't slip with factory tune. I neglected to mention that in the previous posts.
sohfast94
Post by sohfast94 »
Yeah but the factory tune is also weak in comparison to what the predator puts in.. Where does it slip? Intial? Shifting?
lrklyne
Post by lrklyne »
What do you mean where does it slip? It is fine from 1st to 2nd but will slip 2nd to third and 3rd to 4th. And it slips at normal throttle not only when im stompin on it.
sohfast94
Post by sohfast94 »
I dunno man that seems like it's not getting enough pressure from the front pump.. I could understand at WOT but not at part throttle.
lrklyne
Post by lrklyne »
So any suggestions on how to figure it out? I mean like i said i talked to a tranny shop and he said not pullin any codes he has nowhere to start.
lrklyne
Post by lrklyne »
and just outta curiousity why did you wanna know what gears i had?
