few questions on dodge cr predator
on my truck the cylinder peformance test will not work,is this not activated for the 05 trucks?also i would like to know if you can remove the tq management from an 05 dodge,i have aftermarket turbo,injects dual cp3s ,modded fuel supply and a tranny i need more power.i have another tuner that removes the tq management but i like the curve of the diablo better..can you help...bones
Re: few questions on dodge cr predator
Bones if you can call tech support we can get you in touch with the correct person who can answer this. 800.531.5484bones wrote:on my truck the cylinder peformance test will not work,is this not activated for the 05 trucks?also i would like to know if you can remove the tq management from an 05 dodge,i have aftermarket turbo,injects dual cp3s ,modded fuel supply and a tranny i need more power.i have another tuner that removes the tq management but i like the curve of the diablo better..can you help...bones
We even have higher Hp tunes as long as you have the fuel.
Cole Stevens
