Hey guys...please tell me what these do.
Downshift MPH
Shift Time
Upshift MPH
Upshift MPH vs TPS
Upshift RPM
what are these parameters??
02 Tahoe
5.3 w/FLEX
5.3 w/FLEX
RE: what are these parameters??
Downshift MPH: MPH at which it will allow a downshift to happen
Shift Time: How long it takes to make a WOT shift
Upshift MPH: Minimum MPH required for said upshift.
Upshift MPH vs TPS: Control of part throttle upshift points vs. Throttle position.
Upshift RPM: RPM at which a WOT upshift will be commanded.
Re: RE: what are these parameters??
Thanks Mike.mikel wrote:Downshift MPH: MPH at which it will allow a downshift to happen
Can you expand on these answers....
For what Throttle position does the Downshift MPH affect? If I raise it, what happens?
Upshift MPH- so I can raise this and it won't shift until I reach a certain mph? But other variables affect it? Like TPS?
I understand the others! Thanks
02 Tahoe
5.3 w/FLEX
5.3 w/FLEX
RE: Re: RE: what are these parameters??
I believe Mike's out on vacation for a bit...
Honestly, best explaination I can give is to make small changes to these params one at a time so you can 'see' what they do for yourself.
Basically they change the relationship of when the PCM will command an upshift or downshift.
Downshift MPH is the minimum MPH you must be traveling to get it to downshift.
Re: RE: Re: RE: what are these parameters??
So if I want it to downshift sooner, I raise the mph? I want it to downshift easier as I 'tip-in' on the throttle.mikel wrote: Downshift MPH is the minimum MPH you must be traveling to get it to downshift.
02 Tahoe
5.3 w/FLEX
5.3 w/FLEX
