ext puck install issues 06 5.9l cummins 'hit wall"
jmkmlk54
Post by jmkmlk54 »
after extreme puck was installed, truck started hard, then check eng lite is on. Dealer reprogramed, lite stayed on till next morning. PO191 was error code, dealer ordered new fuel rail pressure sensor. before returning to dealer, i tried one more time. truck failed to start after numerous attempts. looks like the extreme puck is not meant for my 06 ram 2500. :cry:
RE: ext puck install issues 06 5.9l cummins
What part number was this puck?
Sounds as if maybe there is a wire on backwards or something improperly connected.
There should be no issues with the fuel pressure sensor.
jmkmlk54
Post by jmkmlk54 »
there are no numbers on this puck. it is red, with the variable speed power selector. the connectors have locking tabs that make connecting improperly nearly impossible. don't know what to do!
