custom tune please,mikel?
rangercliff
mikel, you said in a recent post to send you my file & you could make me a tune to fix my speedo issues. it was not addressed in 9r09 as i was told it would be.i will list my cals again, 12216125 am ecm software,0957712ak eng cal,09358096am eng diag cal,09358203aj trans cal,16264419ah trans diag cal,16264679ab fuel cal,09373498aj veh sys cal,09359159ay veh speed cal. is that all you need or do i need to send you my backup file?
RE: custom tune please,mikel?
Please export the last tune written from your Predator and send that to me and we'll fix the speedo.
rangercliff
last tune
here is my last tune ,02 2500 avalanche,8.1,4x4,4.10 gears,325-50-20 tires,u7198,9r09, THANK YOU
- 3GNGK23G62G219452_custom.grg
- (6.25 KiB) Downloaded 88 times
RE: last tune
Err, i will need your original backup as well for these new units.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
rangercliff
backup tune
here's original backup
- ORIGINAL BACKUP TUNE.grg
- (294.48 KiB) Downloaded 91 times
Give this a shot...
- 3gngk23g62g219452_custom_tire.grg
- (234.96 KiB) Downloaded 87 times
Diablosport INC
Diablosport INC
rangercliff
speedo adj
installed tune & no help, i can moddify sidewall #, or tire height , load tune & speedo sweeps when i go into gear ,start to roll & the speedo pegs.
RE: speedo adj
No, the point here is for you to load the tune and not have to change anything, as the speedo will be corrected through the tune.
Reset all parameters, then reload the tune.
Speedo should be correct.
rangercliff
Bah, tire size sucks doing it by hand. Give this one a shot.
- 3gngk23g62g219452_custom_tire1.grg
- (234.96 KiB) Downloaded 101 times
Diablosport INC
Diablosport INC
rangercliff
