CHANGEING TUNES
CHANGEING TUNES
WHEN GOING BETWEEN 93 TUNE AND THE 87 TUNE DO I HAVE TO GO THROUGH ALL THE PARAM. AGAIN? I HAVE SOME PARAM. TURNED OFF WHILE RUNNING THE 93 TUNE, WANT TO TRY THE 87 TUNE, DO I HAVE TO GO THROUGHT THEM OVER AND OVER AS I CHANGE TUNES? CAN I RUN 89 GAS WITH THE 87 TUNE? AND THE 93 TUNE? THANKS
Re: CHANGEING TUNES
Actually Ford or GM the predator remembers the adjustable parameters. So you can flash a 87-91-93 octane tunes and it will keep your adjustable parameters. You do not have to keep changing the parameters because the changes will carry over tune to tune.mongo53 wrote:WHEN GOING BETWEEN 93 TUNE AND THE 87 TUNE DO I HAVE TO GO THROUGH ALL THE PARAM. AGAIN? I HAVE SOME PARAM. TURNED OFF WHILE RUNNING THE 93 TUNE, WANT TO TRY THE 87 TUNE, DO I HAVE TO GO THROUGHT THEM OVER AND OVER AS I CHANGE TUNES? CAN I RUN 89 GAS WITH THE 87 TUNE? AND THE 93 TUNE? THANKS
Cole Stevens
Diablosport LLC
