2001 sierra " not in database"
longalan2
Post by longalan2 »
i have a 2001 gmc sierra with the 5.3 auto. i have updated the programmer with 9r09. it tells me that it is not in data base. the only tune it shows for it are the factory hp tune. at first it said not in data base. after 2 tries it took the factory hp tune, but wouldn't let me modify it. now it has the unmodified tune in it but claims not to have the vehicle in data base. i was also under the understanding that this tuner would have more than just the factory hp tune. the tuner is U7198. please help the cal id is BB12202088CVA. i have a programmer for my mustang, which makes this one seem like it does little to nothing. are there other tunes that are supposed to be on it?
RE: 2001 sierra " not in database"
it should have more than just the factory hp tune in it...
sounds like you have an un-supported calibration ID...
you'll have to wait for them to create a new revision update to support your Cal ID...
Can you post up the full list of calibration IDs please?
longalan2
Post by longalan2 »
yeah, give me a day or two, the truck is not with me today.
longalan2
Post by longalan2 »
sorry it took me so long. here they are: ecm software-12202088bb / eng cal- 09357812ab / eng diag cal- 09362506ac /
trans cal- 16264170bj / trans diag cal-16264334ba / fuel cal- 16264629ac / veh sys cal- 09359072bs / veh speed cal-09359167ay
let me know what you can do for me. thank you. also here is this one.bb12202088cva
longalan2
Post by longalan2 »
hello,,,,,, anyone home?
We'll be adding this to the next revision update we make for this Predator.
longalan2
Post by longalan2 »
do you know about how long it will be before the next one comes out?
BigYo_71
Post by BigYo_71 »
You can either have your ECU re-flashed at a dealership for over a $100, or wait for the new revision. The re-flashing adds all kinds off updates to your truck, transmission settings, fuel system settings, shift pressures, and other stuff that get your ECU up to date. At least thats how the mechanic explained it to me at the dealership.
CANUCKPREDATOR
Post by CANUCKPREDATOR »
if you want to find out what kind of updates, take in your VIN and ask what's changed.
longalan2
Post by longalan2 »
Thanks guys! I'll call the dealership tomorrow and check on that. I didn't realize that the updates could make it to where the predator supports it.
Return to “Predator GM Gas”
