Hi people from Diablosport...
I have a 2008 gt mustang, borla (exhaust, x-pipe-mufflers.) TB bbk 62 mm, C&L intake, bbk pulleys, steeda spacer 62 mm.
My problem is:
Today i install my Charge motion delete plate, and my car have some problem, is too lean (wide band: 16) or too rich (10.6) my predator show the following codes (unkwowning error and OBDII test incomplete) please help me with this give some clue on this thanks!!
Any help would be appreciated..!!!
2008 GT Mustang - Charge motion delete plate problem
RE: 2008 GT Mustang - Charge motion delete plate problem
Where is the wideband getting its reading from and is this at idle, part throttle, wide open????????
http://www.tpctuning.com
my wideband show the following:
Idle: 16
Part Throttle: between 12-10
Full Throttle: 10.6
I check my LTFT and they are to rich:
At idle i have: -24 to -25
At wide open: -24 to -25
Idle: 16
Full Throttle: 10.6
Where is the wideband located in the exhaust? Which tune and revision are you running and please detail a complete list of mods to the car.
10.6 is wayy too rich... and your trims are out as well. This thing been tuned by someone? Have different injectors?
Insert Clever comment here...
Dialosport 9r03 U-7145
My wideband is located al the exhaust before de x-pipe. my car has the following mods:
TB: bbk 62 mm
TB spacer: steeda 62 mm
Borla: Exhaust, x-pipe, mufflers.
Charge motion delete plate: Steeda.
C&L intake.
MSD coil.
bbk pulleys
my injesctors are the Stock.
The tune was made it by Doug (bamachips).
Give some help please, i need a hand with this.
TB: bbk 62 mm
C&L intake.
MSD coil.
bbk pulleys
Have you contacted me about this? I dont see any emails from you? It sounds like I have the wrong C&L air intake adjusted for, this happens alot as people just say they have the C&L intake and dont specify which one. There is the C&L Street fully aluminum intake and the C&L Racer plastic tubed version.
Email me as I don't come here often and just happened to stumble across this.
Thanks, Dougl
Thanks, Dougl
Hi Doug!! how are you!!??? thanks for the replay, hey i wrote you to your e-mail on gmail ([email protected]) right now i going to send yo a email!!
Thanks again!!
Thanks again!!
Doug is a standup guy and will definetly take care of you.
doug how are you?? man i send you the email, please check if you receive it...
thanks!!!
thanks!!!
