Idle up
Idle up
Hey guys would it be possible to get a tune that has that idle up option. My truck doesn't shut off for weeks when it gets down to -40C up here in Alberta. If there's not enough room in the memory can I change it out for the top speed limiter bypass.
2007 4x4 3500 4" Superlift w/35" BFG MT's, Stage2 AirRaid,ATS Intake Manifold,4" MBRPexhaust,Predator/Econ-Perf, drove hard and put away wet everyday in northern Canada...hence all the metric mumbojumbo....
RE: Idle up
You can enable idle up in the Predator right now....
RE: Idle up
what does idle up do? and how do u do it?
RE: Idle up
Sorry Mikel I've been using the r16 for the last couple months, I found it in the Quick adjust options thanks man.
"thealiffs" it just enables the high idle (push the set button while the cruise in on).
