Speed Limiter Help
tyman09
Speed Limiter Help
Post by tyman09 »
I have the u7153 predator and i just updated it with the new revision update and i go in my rev limits and my speed limits and there is no speed limit section to turn it off anymore.. How do i turn my speed limiter off? My truck is a ford 2002 f-150 2wd with the 4.6L V8..
tyman09
RE: Speed Limiter Help
Post by tyman09 »
help please
rockier
Post by rockier »
I hope they are able to help you. I have been waiting and still have not had any help on this same problem with the same unit.
walding
Post by walding »
Glad to see there are others out there besides me. I thought I was one of the rare one's with this problem. My 99 F150 5.4l has the need for more speed!
tyman09
Post by tyman09 »
yeah for some reason under the rev and speed limits there is no speed limit option its gone... And i wanna shut it off cuz its embrassing getting passed by little 4 cylinder cars when your racing to somewhere.. lol
rockier
Post by rockier »
I agree. I got this unit for this reason and it does not have the option. I cannot even correct the speed odometer.
We are working on an update for this Predator right now that will restore these parameters along with all new tunes.
tyman09
Re: RE: Speed Limiter Help
Post by tyman09 »
rockier wrote:I agree. I got this unit for this reason and it does not have the option. I cannot even correct the speed odometer.
yep i agree with you too i have my axle ratio set at 3.54 as i was told even tho i have 3.55 gears. But its still 4mph off i checked it with a gps..
tyman09
RE: Re: RE: Speed Limiter Help
Post by tyman09 »
when will this update be available?
tyman09
Post by tyman09 »
Should this update be available by the end of next week or when?
kmac1
Post by kmac1 »
This is a very large update and will take some time. It is happening but I can't give an eta because of the amount of work we are going to put into it. For now if you guys want your speed limiters shut off post up your current tunes and we can do it for you. You will need to go into options, troubleshooting and read extra tune. Then hook up the Predator to DSDownloader and from the custom tune menu, export extra tune, then post it up here...
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
heycamp1
Speed Limiter Help
Post by heycamp1 »
U7153 Revision 9 2003 F150 Screw 5.4l CAI/ 3" Magnaflow Catback SI/So Front of Wheel...
I am new and saw the Speed Limiter post about tune to remove. I would like a tune to remove it, Firmest shifts 1-4, 91 octane, Cai, 3" Magnaflow catback, 3.55 gears, best perfomance tune with this info please...
Thank You for all you do!!
2003 F150 Original Backup.frg
(224.25 KiB) Downloaded 350 times
odal1fa.frg
(224.25 KiB) Downloaded 375 times
tyman09
help!
Post by tyman09 »
well i'm trying to get my tune from my tool to post it up here and its not letting me do it? Sorry i'm new to all this stuff.. I went to get tune file from tool is that correct? Well if it is it didn't work so give me steps on how to do this because i've had troubles messing with this and i'm new at it... When i get the tune uploaded i'll post up what i want done to it... Help please!
heycamp1
Speed Limiter Help
Post by heycamp1 »
Hey TYMON,
You will need to Connect to the truck and go into options, troubleshooting and read extra tune. Then hook up the Predator to DSDownloader and from the custom tune menu on the predator, export extra tune, then Remember where you saved it to on your PC. Post it up here by adding the extra tune the attachment.
heycamp1
Post by heycamp1 »
I am new and saw the Speed Limiter post about tune to remove. I would like a tune to remove it, Also I would like the firmest shifts 1-4, 91 octane, Cai, 3" Magnaflow catback in front of rear wheel, 3.55 gears.
I would like the best perfomance tune with this info please...
odal1fa.frg
(224.25 KiB) Downloaded 311 times
Return to “Predator Ford Gas”
