Best MPG
goosemanx
Best MPG
Post by goosemanx »
Which tune would provide the best MPG? 87 or the 91? Also i tow a camper alot in the summer time 2005 gmc sierra,4.8l u7193,v9r09
RE: Best MPG
Mileage will be about the same between the two.
Poetique
RE: Best MPG
Post by Poetique »
Yep.
So by a cost standpoint the 87 should save you the most money, simply because it's a cheaper fuel.
CANUCKPREDATOR
RE: Best MPG
Post by CANUCKPREDATOR »
91 octane will give you the best power for towing. i run 87 for daily driving and 91 when towing (usually a tank before a trip)
sickREDsierra
RE: Best MPG
Post by sickREDsierra »
i use the 2x4 method for best mpg.
take a piece of 2x4, cut it to about 6" in length, and place it under the gas pedal. you can use untreated wood, since its cheaper.
works great!
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
keoni1978
RE: Best MPG
Post by keoni1978 »
I have a 08 Sierra Denali, so would the 87 tune give me the same MPG as the Diablo tune? Thanks
2006 F250 PSD
2008 Sierra Denali-Sold
sceptre
RE: Best MPG
Post by sceptre »
using a HO engine, should you even being using 87 gas? I know it will run and retard the timiing to compensate, but lowest i've ever put in mine was 89.
I haven't been around here long enough to know what is in the 87 tune, but if the engine runs best on 91, wouldn't be hard to push more power out of it from 87? i may be WAAAYYY out in left field...someone please give me some info if I am
Re: RE: Best MPG
sceptre wrote:using a HO engine, should you even being using 87 gas? I know it will run and retard the timiing to compensate, but lowest i've ever put in mine was 89.
We have developed tunes that allow you to safely run 87 octane fuel in these trucks while still increasing performance.
keoni1978
RE: Re: RE: Best MPG
Post by keoni1978 »
I guess I'll give the 87 tune a try and see what kind of MPGs I get. Thanks
2006 F250 PSD
