2003 used loader problem
rustynail
Post by rustynail »
purchased a used loader for my 2003 6.0 Ford F350, code on the box is 2005 6.0, the rev is V.7r75e
when I try to install the loader is says something about "these features are not available for this vehicle" and shows the following codes:
CalID "AKZ2AH19"
VXAN0N2.Hex*
T2AT0A3.Hex*
RE: 2003 used loader problem
Need to update it to the latest revision.
rustynail
Which Rev
Post by rustynail »
Which revision, there are three listed
RE: Which Rev
9r05
rustynail
RE: Which Rev
Post by rustynail »
First I tried to "autoconnect" but it never found my loader, even tried to change the baud rate on both ends still nothing I read about loading a new Crom on the Forum..
I tried to load a new Crom, I couldn't get it to auto connect and read the following "you need to go to the express tune at the bottom of the DSDL page. Then click on options at the top of that page..select legacy connect..make sure the compressed send is NOT checked" I tried to do this, it told me to cycle the power and then it kept timing up but the bar didn't move.. I stopped it and now my loader says "the application is missing or corrupt" and I can't get back to reload it.
what is my next step?
rustynail
RE: Which Rev
Post by rustynail »
okay I read the posts about how to correct for a corrupt application, everything was fine till it started to load, not my loader is flashing
"Cannot load pcm_6-0 application into power_6_0 tool"
what do I do now?
rustynail
RE: Which Rev
Post by rustynail »
okay, I was able to load "u7165_pcm_6_0-8r10_for_power_6_0"
then I was able to load r05
I will try to load it tomorrow
