Caliber SRT-4 Needs your support!!
SRTst
Post by SRTst »
We want some Diablo power!
Don't forget about us!
08BlkCaliSRT4
Post by 08BlkCaliSRT4 »
Where you able to download the info from DCX?
Or do you need more Calids?
08BlkCaliSRT4
Bump....update?
Need all the calids!!!
SRTst
Post by SRTst »
mikel wrote:Need all the calids!!!
Hi,
I have no clue what the CalID is or how I can get it for you. If you explain it a bit further I'm sure we can get you all the required info.
Even if you need the information from within the pcm, I'm sure I can pull some strings and get the info you need but I need to know what you need specifically.
Once my batteries charge for my camera I will take detailed pictures of the PCM and all labels as a first step. You can let me know what further information you may need and I will get the rest of the Caliber community involved.
I should let you know that there are 2 different versions of flashes in the Caliber SRT-4 ECM's. Due to the change of the A/C Compressor housing there is slightly different programming for early Caliber SRT-4's (Pre Jan 15th/2008) from the later SRT-4's (After Jan15th/2008).
SRTst
Post by SRTst »
I took some pictures of the computer. Maybe you guys can see what you need to see here. There is only one small little label that is nearly impossible to take a good picture of. It's about 1/4" x 1/4" and is located on top of the plug part of the ECM.
Let me know what else you need, just please be as specific as you can be so we can hopefully get some movement on this :).
THANK YOU!
Why'd you block out the last 6 VIN digits? Does it really matter? Anybody can just walk upto your car and see the whole VIN. I've never understood that. Same thing with license plates.
That module P/N is the Cal ID BTW
GooberMT
Post by GooberMT »
if they need an additional CalID, i will post up my PCM's info just like SRTst did
SRTst
Post by SRTst »
Mike_Levy wrote:Why'd you block out the last 6 VIN digits? Does it really matter? Anybody can just walk upto your car and see the whole VIN. I've never understood that. Same thing with license plates.
Hi,
Thanks for the info on the CAL ID.
Sure anyone can come up to my car to see my vin... however, you'd be surprised how much information you can access with just model of your Chrysler vehicle and last 6 digits of your vin.
Last 6 digits of the vin are really unnecessary so I chose to leave them out.
Thanks again..
Aaron@Realtune
Post by Aaron@Realtune »
Im gathering the information for you guys now
Owner of Realtune Peformance
10.62@133 05 Neon SRT-4
11.62@128 08 Caliber SRT-4
Worlds Fastest/Quickest Caliber SRT-4
SRTst
Post by SRTst »
GooberMT wrote:if they need an additional CalID, i will post up my PCM's info just like SRTst did
Well if the CalID is the module P/N, you can just verify that yours matches..
It's the one that ends in AB. AB is the revision. (it will go like AA, AB, AC, AD etc.)
GooberMT
Post by GooberMT »
Well if the CakID is the module P/N, you can just verify that yours matches..
Mine is the same but ends differently P05035043AA
My build date was 02/08/08
gsjoe
Post by gsjoe »
gsjoe here. put me down for the CSRT4 also.
my SRT8 preditor is great thank you
My # being P05035043AA
gsjoe
franka12404
Post by franka12404 »
I want diablo power please help us unhandicap are car's and show its true power
SRTst
Post by SRTst »
Hi,
Aaron@Realtune Started a thread about CalID's (Part numbers) on caliberforums.com and in less then 12hrs we gathered a lot of info with many people participating. This should show that there is a great deal of anticipation for this product.
What we have come up with so far:
P05030394AG
------------Part Number Change--------------
P05035043AA
P05035043AB
P05035043AC
*note no confirmation on any revision beyond AC, if this changes we will chime in.
P05034305AA
P05034305AB
P05034305AC
P05034305AD
P05034305AE
P05150525AA
*note This is the latest/current part number for Caliber SRT-4 Computer.
Either myself or Aaron will update this list if it changes any. Please let us know if we can provide any further assistance.
Thank you!
Neven
