ENGINE TEMP.
ENGINE TEMP.
I WAS TOLD I NEEDED TO CHANGE MY THERMASTAT TO A COOLER ONE BECAUSE OF TUNES, IS THAT TRUE? AND KIND DO I NEED? THANKS
RE: ENGINE TEMP.
no, you do not need to change your thermostats...
RE: ENGINE TEMP.
No need to change, that is up to the end user. We give you the option to set the fans however you like to work with either stock or cooler t-stats.
