Ok I'm confused
tim_r73703
Ok I'm confused
the paper that comes with the puck (for a 06 ram cummins) say's that the grove on the switch is for the 50hp setting and on the online manual says it's the 90hp setting so which is which?
06 CTD..5"PROCOMP LIFT WITH 35" MICKEY T BAJA MTX'S..VOLANT COLD AIR INTAKE..AERO TURBINE MUFFLER NO CAT..AUTO METER GAUGES(PYRO, BOOST, TRANS) FUEL GAUGE ON THE WAY..SOON TO INSTALL THE PREDATOR/PUCK COMBO..FASS PUMP IN THE NEAR FUTURE
RE: Ok I
The manual online had the correct position settings.
The other paper needs to be edited.
tim_r73703
RE: Ok I
Thanks......
- duallydave
RE: Ok I
thats what it was,i thought i was on crack when i felt more power on the 50hp setting,now it all makes sense.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
- madmanwithmouse
RE: Ok I
ahh, now that does make sense.thats what it was,i thought i was on crack when i felt more power on the 50hp setting,now it all makes sense.
Sure would be nice if the stock setting was on one side instead of the mid...!
Actuly could a new switch be rewired to do it that way to plug onto the cable?
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
Smitty3500
RE: Ok I
I was told on the phone today that stock is on the oppisite side of the 90 and 60 is in the middle. I cannot get a concrete anwser.
04.5 3500 DRW QC SLT: 600 NV5600 4.10's. BD Intake/AFE PG7 Filter, Power Puck, CB Hose, Remote BD Exhaust Brake, MBRP Muffler, No Kitty, Duraflaps, Isspro EGT/Boost Gauge, Enkay Rock Tamers, LineX, 20k Reese 5ver... for now...
