U7134 9r13 problem with fan settings
I have a 2004 PT with S1 running the Diablo 93 tune. I just installed a 180* t-stat and tried to change the fan on settings. When I went to the setting it would show -74.20* on all settings except the high mph was showing the scale with the dot at 210*. I tried changing the 210* to 195* and if the fan cuts on it never cuts off (still running at 176*). I then tried setting all fan settings to 195* ( the -74.20 will change to 150* on the bar graph with a push of any arrow) and got the same results. Help!
RE: U7134 9r13 problem with fan settings
Post your last tune written.
Insert Clever comment here...
Re: RE: U7134 9r13 problem with fan settings
Last tune.sohfast94 wrote:Post your last tune written.
- 04510630AB_custom.drg
- (2.25 KiB) Downloaded 92 times
Here you go the parameters will be fixed in the next revision... I fixed them for you for now.
- (56.21 KiB) Downloaded 101 times
This didn't work for me. Maybe I didn't do something right. I downloaded this attachment to the handheld and loaded to the car but got same results. I also had a problem with knock the other day maybe due to bad gas and tried to lower timing to get rid of the knock, and this didn't seem to change either. When is the next revision coming out?sohfast94 wrote:Here you go the parameters will be fixed in the next revision... I fixed them for you for now.
