U7152 Not Adjustable?
nebmike
Post by nebmike »
Recent posts have mentioned the U7152 (Ford V-10) tool not having adjustable features at this time... is that just in reference to tire size or are you saying that it ships with standard tuning and no other ability to adjust any of the parameters described for other applications (e.g., shift points, rev limit, rear O2 disable, etc.)?
Maybe I'm misunderstanding the description of the tool, but my perception was that many of the parameters were user-adjustable from the Predator itself.
Thanks in advance for any clarification!
RE: U7152 Not Adjustable?
This and only this tool does not have any adjustable parameters.
We will be updating it in the near future to add the full list of adjustable parameters, and any changes can also be made in a custom tune.
tpd4him
Post by tpd4him »
Mike, If it is true that a custom tune can be made to compensate for 35" tires I would like to get one. I have a 00 Excursion and the primary reason I purchased my Predator was to correct my speedo, the truck does get better milage and has better shift points but I do want to have an accurate speed reading. Please help.
I apologize as I was mistaken about adjusting the speedo in this application.
The speedometer is controlled through the ABS module in these trucks and the Predator does not access that module.
If we come up with a solution for these trucks in the future, we will let everyone know.
Return to “Predator Ford Gas”
