got rma back still does not work
rangercliff
predator 7198 had tire size issues, 40$ on stuff to update to new revision & still won't work, send back as per tech line & all they did was update to rev 9r07, i could have done that myself & it would not have cost me 40$ in shipping.got it back yesterday & it will not calibrate speedo.i have spent almost 500$ on this thing and have got no help with this issue.the main reason i bought the predator was to calibrate my speedo
RE: got rma back still does not work
Please post up your calibration IDs and we will fix this in a new revision.
rangercliff
OK, we will fix this in the next revision.
rangercliff
rangercliff
What vehicle was this?
We are working on a fix now via an update, what vehicle was your problem on?
Can you post the VIN please?
I'm trying to find your original post, but can't.goosemanx wrote:THANKS Mikel, my truck is a2005 gmc sierra 4.8l. VIN is 1GTEK19V95E198947
Thanks again
We looked up these params and they appear to be functioning properly in the latest revision, what revision are you on?
What is the exact error message you see when you try to change the tire size?
U7193. v9r06,I can select these parameters, I adjust them,when I go back and select that parameter again to see if it was changed it say tire size not set, but it does have the * beside that parameter
*Tire width(not set)
*Tire ratio(not set)
*Rim size(not set)
Hope this helps.
Thanks again.
*Rim size(not set)
Hope this helps.
Thanks again.
if it has an asterisk next to it, it has been modified...
when you go back to that tire setting parameter, it just shows the stock/default setting, not what you adjusted it to previously...
So, besides it saying not set, does it change the speedo when you install the modified tune?goosemanx wrote:U7193. v9r06,I can select these parameters, I adjust them,when I go back and select that parameter again to see if it was changed it say tire size not set, but it does have the * beside that parameter
*Rim size(not set)
Hope this helps.
Thanks again.
