doesent load tcm file u7137
yea i got a custom file from johan awhile ago, an when i go to load the pcm file its fine an asks for back up an i do so.. but what about the tcm file? how do i get that to load..
2005 Ram 1500 QC 5.7.
K&N cold air intake, LT headers, 2.5" true dual exaust with no cats...
gomangohemi
RE: doesent load tcm file u7137
If you are not doing it under the advanced tuning tab, then do it there. Check the box to attach tcm file > add pcm file and it will ask will give you options for the orig. backup. It should locate the one you have. After that, it will ask you if you want to attach a tcm file. say yes and attach the file. it will then ask you to save the orig. tcm file. Do so. Then you should click send to tool.
'05 Ram Daytona Q/C 5.7Hemi 4X4
HHP/BES Ported & Polished High Compression Heads
Comp 268 In @ 111
Dynatech long tube headers & high flow Cats
Vararam Hemi under Glass CAI
Diablosport CMR Tune
Comp 268 In @ 111
gomangohemi, where you able to load those files??? Without the vin mismatch error coming up?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
gomangohemi
The first set you sent me, yes. But not the others.johan wrote:gomangohemi, where you able to load those files??? Without the vin mismatch error coming up?
just for clarity, they all load on the tool fine, I get the VIN mismatch after it's attached to the truck.
Comp 268 In @ 111
Comp 268 In @ 111
I had a similar issue Johan. I believe I finally got it correct, but is there a way to verify it?
2005 RAM 1500 SLT 4x4
VaraRam CAI
Thorley CatBack Exhaust
Bright Silver w/Deep Tint
VaraRam CAI
