programer not reading truck
2001 F350 7.3L diesel reinstalled 60hp setting after clearing codes. Truck has to go back to ford died again and will not restart. DS is not able to read the truck. Any suggestions accepted,thanks.
RE: programer not reading truck
Alot of guys are having troubles with the camshaft sensors going bad on our year models.The truck will just die for no reason and sometimes re-start,other times it wont.You might want to see which color you have ,the gray one is the latest and seems to be the best.The black one is the one that gives all the troubles.Hope you figure it out.
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
I have the latest css. I thought it may be the computer, I have put several in, the ford dealer told me the diablo keeps taking out the computers. Ford still has the truck, they think it may be the high pressure oil pump.
Its so NOT the Predator killing the PCMs...the 7.3s are notorious for just killing their own PCMs while driving down the road...
