FLX 7193
Trevor
FLX 7193
Post by Trevor »
I am looking at this programmer, does it do everything that the normal tuner for my truck does and make it flex fuel capable or just make it flex-fuel? I think the flex fuel would be great but I want to be able to do a mild tune with TM reduced also.
Trevor
Post by Trevor »
One other thing, I can load the 87 octane tune and still change the tire size, correct? I don't have to do the whole tune manually if I want to change tire size do I?
Trevor wrote:One other thing, I can load the 87 octane tune and still change the tire size, correct?
correct...
RE: FLX 7193
This tool has limited adjustable parameters designed to keep you from altering the tune too much.
TM is reduced in the tunes much like it is in the other Predators.
I do not believe the tool has any injector slope settings, and any parameters it does have will have a smaller range of adjustment.
