stacked bundle
Blue2003
stacked bundle
Post by Blue2003 »
johan, '03 dodge with the ud-7131 TOW STACKER DOWNLOADED, what kind of r.w.h.p. would make on the 60 h.p. setting? how about on the 90 h.p. setting? what would be the torque numbers for both? and if i remember correctly you said that this set up would not add timing..correct? and the tow download and the performance download has no timing. just the extreme stacker setting. a few folks do not believe me just want to get there minds straight. thank you
johan
Post by johan »
If i recall the two stacker made about 40-50 rwhp more than stock, then basically just add the puck power to it. You might not get the high peaks like 90+50=140 rwhp, due to the fact that the tune offsets some of the power produced by the puck. So i would say to be realistic drop 20hp from the added values and you should be in the ballpark for real world rwhp.
Yes the tow and performance on 03-pre 04.5 do not add any timing in the Predator tunes.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
