Johan OR Mikel......no change
fordracing19
If yall are saying that the trucks did not do this before the revision 12 update, a new revision that is the same as revision 7 with the rough-idle/idle-up/tire size adjustment would be perfect. Maybe Johan can help us out here. I took off the Predator and I am just running the Puck as of now. I would love to put the Predator back on though; the power is unbelievable and so much smoother than stock or with the Puck alone.
'06 2500 CTD 4x4 Sport, Predator/Puck Stack, Boost Fooler, aFe Stage 2, Banks Duals, IssPro Gauges, 5" Lift w/ Fox Shox, 325/65/18 Terra Grapplers on 18x9 Moto Metals, Bushwacker Color Matched Flares, Rumble-Bee Scoop, and lots more.......
fordracing19
That would work great for me. Knowing that I could do tire adjustment was a big reason to go with the Predator. I had good luck with my Predator/CMR tune on my 03 cobra.AUcummins wrote:If yall are saying that the trucks did not do this before the revision 12 update, a new revision that is the same as revision 7 with the rough-idle/idle-up/tire size adjustment would be perfect. Maybe Johan can help us out here. I took off the Predator and I am just running the Puck as of now. I would love to put the Predator back on though; the power is unbelievable and so much smoother than stock or with the Puck alone.
Yep, I didn't have any issues prior to the r12 update. I didn't go on any long trips or anything but probably had 500 or so miles on it before I changed to r12. But then again, I can get mine to do it at least once in the first 10 miles quite a bit. Tire size is a nice option, but if this is jacking up my drivetrain, get me back to r7 till you figure it out!
Hmmm, the plot thickens, let me see if i can come up with a test update for you guys to try that will not have the tune on the fly but with the new tunes applied.Should not be a biggie to get done.
Anyone that would like to try it shoot me an e-mail and as soon as i get it done i will e-mail you the test update.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
justlooking
Johan,
I had version R07 and went to the R14 version and I am getting the cut out. Not as bad as some of you. I did get it today going into work that was pretty bad. When I had the R07 I had the rough idle but not the cut out. I live in South Florida so I can get with you guys and try to find the problem. Let me know what is involved in capturing the problem. Thanks, David
2007 Dodge Quad Cab 4x4 Long bed. 5.9 and 48RE. Predator, MBRP cat back, 315/70/17 Hankook MT
Update is taking a little longer than expected. One thing we could try is to run the R14 on the stock tune setting and see if it surges if anyone would like to check that out that will help.
Diablosport INC
Diablosport INC
Haha. Yeah I definately agree there. I'm sure they will have a tune finished before long. I have talked to a guy by the name of Gary in tech support and I know that Johan is working on this thing constantly. He's doing his best and hopefully there will be something within the next few days. At least they aren't abandoning us like some other companies I know of.
On a side note... I want to commend Johan, Gary, and the whole Diablo Sport team. I have talked with them and they are doing their best to resolve these issues. These days it's kind of hard to find a company that tries to work with the consumer that is having issues. In most cases the manufacturer wants to point fingers at other manufacturer's items that are on the same truck (This can be taken to a much wider perspective as well). Companies such as Diablo Sport are the ones (and some of the only ones for that matter) that I enjoy doing business with. It's a business like this that I will gladly shell out a few more $$$ to do business with simply because they stand behind their products and have excellent customer service. Kudos Diablo Sport. Keep up the great work!
