Hey all,
Just purchased a brand (new) used 2006 Daytona Charger. After doing a bit of research on the Internet, I see the previous owner has used Superchips Flashpaq on the car. At this time I have no idea if the car was taken back to stock before it was sold.
Since I own a Predator, could use that to take the car back to stock? If so, how do I do that?
Thank you for any help,
CM
New car has been Superchipped: Needs to back to stock
ChaoticMachinery
RE: New car has been Superchipped: Needs to back to stock
Try to backup whats on the car. It'll let you know if its not stock.
Also, if the Predator tells you that the vehicle needs a calibration update, it will rewrite the PCM with a new updated stock file which will allow you to start from scratch.
ChaoticMachinery
Re: RE: New car has been Superchipped: Needs to back to stoc
Mike,mikel wrote:Also, if the Predator tells you that the vehicle needs a calibration update, it will rewrite the PCM with a new updated stock file which will allow you to start from scratch.
That is exactly what I wanted to hear!
Thank you,
CM
