Ford Excursion 2004 6.0l
U7165 V.9r05 serial # 7f000953
I had the V.9r04 and it was surginng badly with the 100hp tune only so I updated it to the V.9r05 and it is ding the exact same thing in 100 hp tune. Haven't tried the 60 hp yet on the new tune.
It is basicly cutting out like lack of fuel is the best way I can describe it like you are riding with someone that is driving a stick shift for the first time in their life. Makes ya feel like a milk shake!!
Can you help me with this please?? any help would be greatly appreciated!
Thank you!
U7165 latest update surging badly
RE: U7165 latest update surging badly
You need to specify your calid... got to options>troublshooting>showcalid.
Insert Clever comment here...
That's not the latest update... Here is the latest update.
- u7165_pcm_6_0-9r06.crom
- (827.48 KiB) Downloaded 125 times
Thanks for the reply. Sorry I forgot the calibration ID its VXAP2A2
I did try the u7165_pcm_6_0-9r06.crom that you posted thanks! But it did the exact same thing. It is cutting out bad at hard excelleration instantly and then it is fine until 0-1/4 throttle, it is if I am just pumping the gas pedal on and off. Best I can describe it I hope that helps!
Thanks again!
Keenan
Thanks again!
Keenan
If you look here I fixed the issue with the VXAP2's I'll re-do the tune and have a new rev here in a bit...
http://www.diablosport.com/index.php?na ... ic&t=12531
Here is the new crom...
- u7165_pcm_6_0-9r07.crom
- (827.15 KiB) Downloaded 110 times
ok I just tried it the 07 rev and no dice it was better at hard excelleration but still real bad at just cruise speed no matter how fast i hold it steady at one speed it is just cutting in and out like pumping the gas its just cutting out like its starving for fuel intermitantly. give it gas its fine b ack off its starts to gag again 60 hp runs like a charm like the others did.
Is it from being stock other than the programmer?? cant hadle it?? no engine check light or anything !
