want more ponies, rockers arms?!?
Just curious if any body is running different ratio rocker arms/how well they work, comp cams seems to have a good set up. Also were do you fnd the engine code to figure out what pushrod size you have, i.e. 5/16 or 3/8. Or you just have to pull the valve cover and measure? Oh BTW i have a 2006 HD 6.0L
RE: want more ponies, rockers arms?!?
I put cane full roller rocker in my 2004 GMC sierra 6l with 1.8 ratio the stock ratio is 1.7 it may a difference in power and gas mileage.
I not sure about ths size of the push rods ithe kit I order from Jegs came with new push rods which were a little larger but everything work just fine.
Hope this helps.
Hope this helps.
joeyz71
Hey, so ya know the 8th digit of your VIN is your engine code. It might still be a U for the 6.0, but maybe different now with all the flex-fuel stuff. Good luck.
I just put 1.8 rollers on a 2000 Silverado 4.8. Made it sound a bit more choppy and gave a little more power, but I wont be buying any for my truck. Wasnt worth the time or money IMO. The stock rockers are really not bad at all. If I were you I would go with a set of longtubes and an intake if you dont already have that.
