Adjustin fuel % on an 04 srt-4
04eblue
Post by 04eblue »
I seen on the Diablo website that fuel can be adjusted +/- 20% but when i go into the programming features the programmer lists fuel adjustments +/- 40%.
I am running stage 2 w/o toys and using the stage 2 pcm. The car is leaning out above 4k at WOT and the afr is between 9.5-10.5. I added 8% fuel for between 4k and 4.8k and it dropped to 8.9-10.
.......well now i realize that is rich not lean. My bad.
Time to pull a little fuel now.
04eblue
RE: Adjustin fuel % on an 04 srt-4
Post by 04eblue »
Oh and also running a Kinetic WGA and pushing 20psi and holding about 18. The WGA has a 14lb spring. I am wondering what route i should go. Pull fuel above 4k and leave the boost as is or adjust the boost since i am running lean below 4k at 3/4 throttle and then start adjusting fuel from there.
Hope i didnt confuse you guys.
sohfast94
Post by sohfast94 »
Yeah just pull fuel above 4K.
Insert Clever comment here...
