2004 SRT4 slight hesitation and 20 psi
srt-cuatro
Post by srt-cuatro »
pn u7134
9r15
2004 SRT4
I just installed the 93 tune and I made a 2nd and 3rd gear passes till redline and I was getting 20psi and there was a slight hesitation. Could it be a surge? Is there a way to set my PSI at a certain level"? My mods are a 55mm Throttle Body, Injen intake, S1, and catback exhaust.
sfla_srt4
RE: 2004 SRT4 slight hesitation and 20 psi
Post by sfla_srt4 »
Do you have a WGA??? Should not get 20 psi on the stock WGA... Need some more info here. Do you have a wideband?? What are your plugs at??
srt-cuatro
I have the stock WGA. I dont have a wideband. What plugs? I am going to do some data logging but i dont have a laptop. Thanks for the response.
srt-cuatro
Also, does the DS adapt like the S1 does?
srt-cuatro
I logged a 3rd gear pull to see if anybody can help me tune the kr out.
3880 Knk ST 1.0, 19 SPK CYL 1, .08 OL AIR FUEL
4300 KNK ST 2
4700 KNK ST 4.5, 20.50 SPK CYL 1
5000 KNK ST 5.5
5200 KNK ST 6
5500 KNK ST 6, KNK LT 1
5600 KNK ST 6, .09 OL AIR FUEL, 22.5 SPK CYL 1
5800 KNK ST 5.5, .07 OL AIR FUEL.
sfla_srt4
Post by sfla_srt4 »
Thats a lot of knock... The OL air/fuel is nothing usefull to you.
Your spark plugs.. Also, what octane of fuel are you running?? Hows the tempature from where your from?
srt-cuatro
Im running 93 octane, its 66 degrees out here and i got irridiums.
sfla_srt4
Post by sfla_srt4 »
what gap on the plugs?? Irridiums are not the best for the car.. Stock champions are good as well as the NGK 4306's. I still dont understand how your getting the 20 spike on the stock WGA.. Are you in a high gear?? What RPM are you at before you get into it?? Did you adjust any parameters on the tune??
srt-cuatro
I think they come stock with .40. When it spiked to 20 I was in 3rd gear and this was right after I installed the 93 tune. When i did the datalog with the handheld it didnt do it anymore. I havent changed any of the parameters on the unit.
sfla_srt4
Post by sfla_srt4 »
Lower the gap a little.. go to around .35ish. What is it boosting now? How many runs/pulls did you do with the tune??
srt-cuatro
It is boosting 18-19 falling at redline. I did 2 pulls. What will reducing the gap do? Should i change any parameters?
srt-cuatro
I put the stock tune back in my car and now I get KNK ST 4.00. I dont know whats going on. its 43 degrees outside.
sohfast94
Re: RE: 2004 SRT4 slight hesitation and 20 psi
Post by sohfast94 »
srt-cuatro wrote:I put the stock tune back in my car and now I get KNK ST 4.00. I dont know whats going on. its 43 degrees outside.
You have a catchcan?
Insert Clever comment here...
srt-cuatro
RE: Re: RE: 2004 SRT4 slight hesitation and 20 psi
Yes I have a AGP catch can.
sohfast94
Post by sohfast94 »
Post your last tune written...
