04 GTO, Predator Tuner
oneslowGTO
Post by oneslowGTO »
I have an 04 GTO with K&N Cold Air Intake, other than that everything is stock. I'am a first time user with the tuner and need some help. What tune and modifications would you reccommend for the most noticable power?
RE: 04 GTO, Predator Tuner
Simply install the performance tune and let it rip.
If you want to get further into it, follow the stickies on how to dial in the fuel trims and enjoy.
oneslowGTO
I installed the Predator Tune, did not notice any difference.
gump2388
Post by gump2388 »
Give it 50 to 75 miles of driving and it will learn everything then log the data for the ltfts it will take a little while before it will be full power
Thats odd...A4 or M6?
Did you have good fuel in the tank?
oneslowGTO
what do you mean my A4 or M6?? It could be because before i was running 89 Octane..so im waiting for the to run out so i can fill up with 91...
Automatic (A4) or Manual (M6)?
If you had 98 octane in there, you were likely experiencing Knock which will reduce power output.
Get some good gas in there and let it rip.
oneslowGTO
ok, its an A4...do i need to let all the 89 octane run all the way out before putting 91 in??
yeah, the diablo tune is made for 91/93 octane... need to run high octane, good gas in there...
mobil, exxon, sunoco, amoco or bp...
As far as you can...
oneslowGTO
ok thanks!
2004 Pontiac GTO A4
K&N Cold Air Intake
Diablo Sport Predator Tuner U7193
PaceSetter Long Tube Headers
pas_04GTO
Post by pas_04GTO »
What is the diablo sport performance tune based on as far as 04 GTO mods, such as mid pipes or headers? Would I be better off changing parameters or keeping the performance tune if I added one or both mods? Also, does the tuner have a 89 octain performance tune?
there is no 87 or 89 octane tune... those cars are meant to run on 91 octane at the lowest... you need to run 91 or 93 octane...
if you add headers, you will need to adjust parameters for the tune...
if you add CAI/exhaust, you SHOULD adjust your tune to get better performance and get your fueling dialed in correctly...
the preset tunes are based on stock vehicle setups...
oneslowGTO
could anyone tell me the stock parameters on an 04 gto??
2004 Pontiac GTO A4
K&N Cold Air Intake
CANUCKPREDATOR
Post by CANUCKPREDATOR »
parameters? like what?
