2004 SRT4 slight hesitation and 20 psi
srt-cuatro
RE: Re: RE: 2004 SRT4 slight hesitation and 20 psi
Its just the 93 tune that comes with the tuner. I dont have a serial to usb cable yet.
srt-cuatro
could the catch can cause it? I do remember hearing a ticking noise after i installed the catch can.
How about this. Go to options>troublshooting>show calid and post what that says.
Insert Clever comment here...
srt-cuatro
PCM: 04510055AE
Alright I figured out your issue although you're going to have to locate some cable to get the update.
Brian,
It would nice if you'd articulate your thoughts and elaborate more on the resolution for issues like these. I consider myself competant with calibrations but usually I have no idea how you can come to any sort of a solution with such little info given to you.
Your insight when resolving these smaller issues will help all of us better understand the PCM logic, especially when the single user CMR is finally released.
srt-cuatro
Re: RE: Re: RE: 2004 SRT4 slight hesitation and 20 psi
duster360 wrote:Brian,
Simple. His file was originally used as a test file and somehow got misplaced since about 9r03.. I have a seperate folder for the originals and the tunes as well as two different servers. His file simply dissappeared from my server so it's hasn't been updated in forever and since it was originally used for testing never had a full tune for that file. Now it does. That was all nothing catastrophic happened. Thus 9r16. You must remember 90% of the updates are due to Stage calibrations that were not supported mainly because you cannot get them from chrysler so our only way was to update as necessary when we found people that had different reads than the original list we started with... The stock PCMs are not like this they are superceeded to the lastest calibration automatically. The Mopar PCMs do not superceed. Mopar made 2-3 sets and that was it.
srt-cuatro
28patrick28
