2004 srt-4 stage 2 overboost
paragod
Post by paragod »
I have an 04 srt-4 with stage 2 no toys, aem sri, mopar/borla exhaust w/ 3" catted dp. I have the u7134 w/ crom 9r16, PCM 04510814aa. Since I have gotten the preditor, on 93 tune it will spike 22ish and then climb to 25ish. I have tried lowering boost wit the preditor but still overboosts. I've tried opening spark plug gap on my ngk iridium plugs and put v-power plugs, still overboosts. Need help, I did email you a few weeks ago with a log.
Letxen3
RE: 2004 srt-4 stage 2 overboost
Post by Letxen3 »
can you post a log file?
~James 2004 PT Cruiser GT
paragod
Post by paragod »
here it is
Letxen3
Post by Letxen3 »
it seems to be running just right for a stage 2, max psi was 23.09 psi. when you said you have stage 2 you have the s2 wga and s2 injectors right? do you have a wideband if so what is it reading?
sfla_srt4
Post by sfla_srt4 »
are you reading boost off your gauge or the predator map readings?? Usually the gauge is off a little. Wideband?? If so what are the a/fs??
duster360
Post by duster360 »
I agree,,,I don't see much of a problem either. Does it run well??
With that said, if you maxxed out the Boost adjustment(-40%) but it has 0 affect,,thats a concern.
Needless Torque Calibrations
www.needlesstorque.com
paragod
Post by paragod »
No wideband, waiting on tax $. Car runs like a raped ape.
sohfast94
Post by sohfast94 »
It should. Is your DAB on 3? Cause then it will get to about 23-25... Made good power and didn't knock so I left it alone... AMde a lot of power actually.
Insert Clever comment here...
Letxen3
Post by Letxen3 »
i think he said in his 1st post that he doesnt have toys. so i guessing he doesnt have dial a boost feature.
paragod
Post by paragod »
no toys, just worried when I saw my gauge pointing straight down. No car runs great, I saw no knock intially and about 3 toward the end. Also, I have the mopar surge with blue plate, I guess the surge valve can hold boost.
Letxen3
Post by Letxen3 »
hehe you needs to get rid of that 20psi factory boost gauge and get a 30/30...i have an extra autometer lunar boost guage if you want it.
sohfast94
Post by sohfast94 »
Yeah the stage guys I worked with had pressure only gauge that went to 30 something.
jalexiou
Overboost with S2 & 93oct tune
Post by jalexiou »
This is my log when trying out the 93oct tune from my SRT-4 with Stage-2 and t/toys. I tried several DAB settings and got interesting results. Here is a summary:
Code: Select all
Time    DAB      Rpm     Boost (kPa/psi)
2:26     2      3000    192 / 13    * looks normal, until..
2:27     2      4000    250 / 22    * I let go of thottle to prevent damage
3:13     1      3000    192 / 13    * with large swings
3:15     1      4060    245 / 21    * immediate let go of throttle
4:55     0      3500    137/  5     * looks normal, until..
4:59     0      4900    160+ / 9    * start of overboost event. stoped it.
[/size]
In closing, I think us staged SRT-4 owners should not use the 93oct tune, unless someone has figure out how to scale it for the MAP/TPS/WGA we use. Notice also that with DAB 0 the peak throttle voltage is lower than with the other settings. No knock retard recorded despite seing 21-22 psi boost.
I am scared to use this tune, and when I get a wideband I am curious to see how lean this makes by car. I guess I have to start from original tune and tune from there.
Predator model u7134 rev 9r17, tune ID 04510060AA. 2004 SRT-4 with S2 only.
dwaleke
Re: Overboost with S2 & 93oct tune
Post by dwaleke »
jalexiou wrote:This is my log when trying out the 93oct tune from my SRT-4 with Stage-2 and t/toys. I tried several DAB settings and got interesting results. Here is a summary:
Code: Select all
[/size]
Is there any cause for concern here? What causes the sudden increase in boost over 4000 RPMs?
I see a simliar situation with my 93oct tune (rev9r17 tune ID 04510814AA) which brought me to this thread. I need to do some more diagnosing before suspecting something is wrong with the tune though.
dwaleke
Post by dwaleke »
Is it possible that the Stage 2 93 Perf tune has a clitch simliar to what was found in this thread on the forum here?
http://www.diablosport.com/index.php?na ... ic&t=14365
