stacking help
blackjack6969
stacking help
Post by blackjack6969 »
:twisted: Im new at this I would like to stack the banks bullet and predator what seting do i use . Is their a stack seting that is not the 200hp one . I think that is to much for me right now .
kw5.9
Post by kw5.9 »
not familiar with banks products the predator uses timing and durations so if the bullet does the same you will have a problem depending on what yr ur truck is y should have 4 stacking options stack the predator with a pressure box like the puck or extreme power puck.
good luck
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
ModManiac
Post by ModManiac »
I would only use a pressure box such as the puck or mp8 with it.
2003 Dodge 2500 Cummins, 6-speed, straight pipe, DS Predator and puck, K&N Cai
5point9
Post by 5point9 »
This has proven to be a good monster stack for me! The bullet can defuel it's part when egt's get too hot. With the predator alone, I don't see more than 1400deg. So I can crank the bullet, let it do it's thing, and if egt's get too hot (which they will with a predator/pressure box stack), the bullet will defuel! Works awesome, can't wait to hit the track!
