KPA to PSI???
KPA to PSI???
how do you convert the KPA reading to a PSI reading?? The map is shown in the KPA form and im trying to figure out how to read it as PSI.. Thanks!
RE: KPA to PSI???
http://www.csgnetwork.com/presskpapsicvt.html
To convert kilopascals to pounds per square inch, multiply the kpa value by .14503773773020923
RE: KPA to PSI???
Then the values are wrong on the trinity... When I put the boost gauge around "0", it says ~100Kpa... Could you guys look this up to see? When im crusing on the highway, its around ~65Kpa, and im in vac, deffentily not 9lbs of boost lol..
RE: KPA to PSI???
0 Boost is atmospheric pressure, which is 14.7 psi....so, 100kpa x .1450377=14.50377, right about 14.7 psi which is atmospheric...
RE: KPA to PSI???
ahhhhh thanks then.. Forgot about the baro.
parsonsproject
ChrisMyers1
Yeah, it is simply the way the factory PID works.
I was logging our Duramax this weekend and it shows actual PSI with 0 being atmospheric.
