U7146 REVISION UPDATE RELEASED!
You will be able to reload your custom tunes after the update.
Hi Kev, can you expound a little about the RPM limiting issues in Mach 1's that was fixed with this release? I was noticing just today that I can't get my 1-2 shift RPM to happen where I want it to (6000), even when adjusting the RPM setting down pretty far-- it still waits until about 6400 to shift.
J Doug
2003 Mustang Mach 1
U7146
2003 Mustang Mach 1
U7146
99azgtstang
Re: RE: U7146 REVISION UPDATE RELEASED!
i have ford mustang 2004 v6 3.8L and i used U7146
i installed my u7146 tune predator 93 octane what can i do if iwant to
change it setup to 91 octane
- Vas@Diablosport
the 93 octane canned tune is for use with a minimum of 91 octane fuel as is. so you should be fineyaixi wrote:i have ford mustang 2004 v6 3.8L and i used U7146
i installed my u7146 tune predator 93 octane what can i do if iwant to![]()
No, i don't work here.
