The Mph is off on my speedo in a 2001 f-250 with the 7.3/ auto trans.
How do I correct this?
Thanks.
Frog
MPH Off on Speedo? 2001 f-250 7.3 / auto trans
RE: MPH Off on Speedo? 2001 f-250 7.3 / auto trans
That can only be done with the factory tool, our predator does not support that, is under the ABS module under customer preferences and it can be adjusted for about a 35" tire thats the limit off the factory setting at least with a NGS maybe different with Fords new IDS tool hope this helps you...
