Steeda CAI & U7145 DiabloSport Predator
RE: Steeda CAI & U7145 DiabloSport Predator
Any help !
PATIENCE!!! LOL
You have the 90mm BUT I do not see an 85mm Steeda tune anywhere in this revision. Are you sure there is one in your menu? You should have the following:
91 Octane Steeda
Steeda 90mm IMRC delete
Steeda 90mm IMRC Firm Shift
Steeda Firm Shift
All of the above are for the 90mm cai like yours. The only difference is the two in the middle are for IMRC deletes. Is that not what you see?
Kevin@Diablo
91 Octane Steeda
Steeda Firm Shift
Kevin@Diablo
which one should I run .. I want smooth shiftting for everyday driving
what the IMRC stands for ???
thanks a lot
thanks a lot
IMRC = Intake Manifold Runner Control they are also referred to as CMCV = Charge Motion Control Valves. They are located in each intake runner and look like a throttle plate. Their job is to induce turbulence and increase port velocity. This helps emissions and efficiency at low load/rpm. Some people remove them because they believe they will make more power and the two IMRC tunes are for that purpose. You should run the 91 Octane Steeda tune, it works great with the intake and a minimum of 91 octane fuel in the tank. Steeda firm shift will be a very firm shifting race like tune that requires 93 octane minimum.
Kevin@Diablo
Kevin@Diablo
I install the Steeda 91 Octane tune and test the car .. the difference is clear and noticable .. I appreciate your help and thank you very much
I want your opinion on the elbow tube Steeda cai .. I mean do you recommend it .. Is it effecting the performance and how many HP should I expect from it ??
Thanks a lot
Thanks a lot
If your car is near stock you will see little to no gain with the pipe. I've tested many intakes and the closer you get all the your conditions(engine/air/oil/trans/rear end temps and environmental conditions) the closer the hp numbers are. In the end the power numbers are almost identical between them all but duplicating the conditions under which they are tested is the difficult part...
Kevin@Diablo
Kevin@Diablo
